Old 01-15-2013, 10:03 PM   #1
Tom in SW VA
Tom in SW VA's Avatar
Default Marvel Mystery Oil
How many Fordbarners use Marvel Mystery Oil in your gasoline or in the oil? It has done wonders for my cars.
Tom in SW VA is offline   Reply With Quote
Old 01-15-2013, 10:09 PM   #2
Mitch//pa
Default Re: Marvel Mystery Oil
tom here is a recent 94 post thread about who uses it etc..you can do a search for alot of information thats been discussed
http://fordbarn.com/forum/showthread...el+mystery+oil
Old 01-15-2013, 11:33 PM   #3
duffer
duffer's Avatar
I use 4 oz at every fill up.
duffer is offline   Reply With Quote
Old 01-15-2013, 11:41 PM   #4
Ca. Kid
Ca. Kid's Avatar
Ditto
Ca. Kid is offline   Reply With Quote
Old 01-15-2013, 11:43 PM   #5
TerryH
TerryH's Avatar
I also use it every time...........
TerryH is offline   Reply With Quote
Old 01-15-2013, 11:56 PM   #6
Pete
I use it in all my shop in-line air tool oilers.
Old 01-16-2013, 01:26 AM   #7
Skibb
Skibb's Avatar
4 oz every fillup plus some in the oil. Thanks to the Ford Barn for educating me about it. Also use it in the A's tow vehicle ('97 F250) and it made a huge difference - it was a marvel - ous difference. Why ? I have not idea but it worked wonders.
Skibb is offline   Reply With Quote
Old 01-16-2013, 06:26 AM   #8
Loyd Nix
Every time I gas up. The fellow who rebuilt my engine told me it it is "top oil" and keeps the valves from hanging up. It offsets the unleaded gasoline.
Loyd Nix is offline   Reply With Quote
Old 01-16-2013, 07:21 AM   #9
springerpete
springerpete's Avatar
I use it for every fill up as well. Have not tried it in the oil but I do add a dash each am to my coffee. Seems to make me step smoother !
springerpete is offline   Reply With Quote
Old 01-16-2013, 07:44 AM   #10
Ross/Kzoo
Ross/Kzoo's Avatar
Does your coffee look like there's an oil slick on it?
Ross/Kzoo is offline   Reply With Quote
Old 01-16-2013, 10:28 AM   #11
gilitos
gilitos's Avatar
What does "done wonders" mean? What differences have you seen?
gilitos is offline   Reply With Quote
Old 01-16-2013, 11:18 AM   #12
earbleeder
I'm trying it in my A now. Add some at fill up just as preventitive medicine. We'll see if it does anything.
earbleeder is offline   Reply With Quote
Old 01-16-2013, 01:07 PM   #13
bluesman31
bluesman31's Avatar
i was wondering the same thing
31 Deluxe Roadster
bluesman31 is offline   Reply With Quote
Old 01-16-2013, 01:22 PM   #14
68HILLBILLY
68HILLBILLY's Avatar
I use it more as a preventative measure.
68HILLBILLY is offline   Reply With Quote
Old 01-16-2013, 01:35 PM   #15
broommaker
I carry a 4 oz. bottle of the oil for every fill-up, works good for the old Phaeton.....
Jim
broommaker is offline   Reply With Quote
Old 01-16-2013, 02:05 PM   #16
Ross/Kzoo
Ross/Kzoo's Avatar
I had a little valve sticking in a 31 Buick and it totally cleared that up. A great upper cylinder treatment when used in the gas. I can't remember if I've used it in the oil.
Old 01-16-2013, 02:22 PM   #17
joe plumber
I use it every oil change
joe plumber is offline   Reply With Quote
Old 01-16-2013, 02:26 PM   #18
SDJason
SDJason's Avatar
same here - no idea if it's actually doing anything for me (it's certainly not hurting), but it's cheap enough that I don't care about the cost, and if it DOES have a benefit, all the better...
SDJason is offline   Reply With Quote
Old 01-16-2013, 02:46 PM   #19
BrianBurkert
BrianBurkert's Avatar
My friend told me that if you have valve seats that are ground on the wider side, the unburnt Mystery Oil collects on them, causing carbon to stick. Thus, poorly sealing valves and eventually other problems. Not sure if there is any merit to his theory. Thoughts?
I've found that at modern highway speeds the babbitt pounds out long before the top cylinders wear out, so what's the use? Nobody around here seems to want to repour an engine without boring the cylinders out and doing the whole thing over.
Personally, I did have a sticky valve issue and a one-time dose of MMO seemed to help that.
BrianBurkert is offline   Reply With Quote
Old 01-16-2013, 03:09 PM   #20
Skibb
Skibb's Avatar
Re: Wonders and Marvel...
In the A, it's use has smoothed out a rough idle; and, the engine does not backfire as we slow down at speed for a red light (that expression "at speed" is used loosely). You wont find any hills in our part of South Florida so can't speak for a decent on a steep hill. For the '97 F250 at 200,000 + miles, there has been a sharp improvement in acceleration. The truck was driving tired and as I wanted to use it for the Blue Ridge Tour,the Marvel was added. Put off getting a replacement truck any time soon.
