Old 07-30-2010, 11:09 PM   #1
runninrich
Question 36 spring perch
While changing the frontspring on my 36 I noticed that the perches at the front of the radius rod ,which holds the shocks, were not evenly spaced from the center of the spring bolt ,one perch was 20 on center the other was 22" on center. This doesn'tseem correct. Before I go any further I would like to know if this is a problem. and how do I rectify it?
Thanks
runninrich
runninrich is offline   Reply With Quote
Old 07-31-2010, 06:28 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: 36 spring perch
installing the new spring should bring it back. without the front spring the front end can move from side to side it would be limited by the shock links binding.
Old 07-31-2010, 09:51 AM   #3
Ed Pitts
Ed Pitts's Avatar
Here is the spring and axle on my 36. Everthing is centered up. Ed
Ed Pitts is offline   Reply With Quote
Old 07-31-2010, 10:55 AM   #4
jerry grayson
Thanks
runninrich
Are these measurements with the new spring installed? I would bet that the spring center bolt is broken and has let the leaves shift.
jerry grayson is offline   Reply With Quote
