Old 08-29-2012, 07:37 PM   #1
hardtimes
hardtimes's Avatar
Default Fuel pump install help...
I just rec'd my new carter elect fuel pump(pictured).
The instructions say to disconnect the mechanical pump...hm, just got that online. So, do not want to get rid of that. This electric pump is a 'pusher' type.
My question is...can anyone explain / picture plumbing where I can use both pumps. And, does a pusher mean that the mechanical pump will NOT be able to draw fuel thru elect pump..when elect not activated??
Old 08-29-2012, 08:03 PM   #2
Step-down
Step-down's Avatar
Default Re: Fuel pump install help...
In my shoebox i installed a 6 volt inline elec. Carter fuel pump to prime her then turn it off and run off mechanical pump. The only problem is the mechanical pump can't pull fuel thur after 30 mph. The key is to create a by pass with a one way value... Do a search there a couple good post to help you on your way ...
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 08-29-2012, 08:11 PM   #3
Don
Don's Avatar
I think I would get a different pump,I got mine from Airtek,can't remember the number,but ie works fine as a primer or runner,no problem with mechanical pump pulling thru it..
DON P
Don is offline   Reply With Quote
Old 08-29-2012, 08:40 PM   #4
41Fordor
41Fordor's Avatar
This hot weather is taking a toll on our flatheads! You can get a one way valve on ebay, I think they're for marine use. I just plumbed a bypass with 1/4 "T" compression fittings:
41Fordor is offline   Reply With Quote
Old 08-29-2012, 09:26 PM   #5
hardtimes
hardtimes's Avatar
41Fordor,
Ha,ha! While you are here posting this helpful pic and showing a solution to my question/problem, I'm on the 'search' area....viewing your input and the same picture You entered there. Ford minds run in the same road,eh!
Thanks much for your effort/courtesy here! And, I'm using the same carter pump setup, only 12V! I think that I can do this setup, but wonder if running rubber gas quality line, in place of your metal bypass fabrication...will work? Mabe not fancy , but functional?
I see in SEARCH area, that several guys state that this pusher pump...WILL... push gas thru the mechanical pump...is that possible and without damage to the mechanical pump??
Old 08-29-2012, 09:37 PM   #6
41Fordor
41Fordor's Avatar
As long as your mechanical pump doesn't have a bad diaphragm...then gas will run straight into the crankcase. But that'll help clean your sludge out!
Old 08-29-2012, 09:51 PM   #7
Dec211975
41Fordor, I like your bypass but was wondering about the Fuel filter; fuel would only be filtered when the boost pump runs? is there another fuel filter.
Dec211975 is offline   Reply With Quote
Old 08-29-2012, 10:15 PM   #8
hardtimes
hardtimes's Avatar
Good point, but easily added before the one way valve and/or up near carb!
Old 08-29-2012, 10:25 PM   #9
41Fordor
41Fordor's Avatar
True, I should have plumbed it a little differently. But it's run fine without a filter, the metal bowl pump has a screen and sediment bowl. I pulled and flushed the tank after sitting for 30 years. And as often as I change my jets for tuning at high altitude, I can just clean out the carb bowl...
Old 08-30-2012, 08:43 AM   #10
Ralph Moore
Ralph Moore's Avatar
I'm running both Mechanical and electric pumps with no problems(now). The electric is near the gas tank, so it pushes fuel, and I installed a regulator right after the pump. Reg is set at 2 PSI.
I probably don't need the elec pump, now that the mech is rebuilt, but it was there when I bought the car, and it works.
Ralph Moore is offline   Reply With Quote
