I repaired an old trunk to put on my original 1931 Tudor. I used "black wood furniture stain" to make it all the same color. However, it turned out too shiny (sp?) for the faded paint of the Tudor. Question: What method or substance can I do to remove the shine of the trunk's finish? Thanks.
Bill Lee/Virginia Peninsula |
Have you thought about flat black rattle can? or a black primer?
Dirt?
What about a dry dust of spray paint, maybe a couple flat dark primers?
try four 0 steel wool and a very light touch Its worked for me more than once ; good luck on your project
Bill Lee/Virginia .....................
You might try a Scotch-Bright pad. If that doesn't work, then you could re-paint it. MIKE ![]() |
![]() ![]() ![]() Jim |
