Old 02-03-2012, 11:51 PM   #1
CRguy
CRguy's Avatar
Question '31 cowl light arm pad or gasket?
The '31 roadster I just bought has old homemade pads between the arm & cowl. Apparently these were not originally used? Do you guys use anything there to keep water from seeping in? What about a small amount of sealer or a thin o ring?
Thanks, Mel
CRguy is offline   Reply With Quote
Old 02-04-2012, 12:22 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: '31 cowl light arm pad or gasket?
I would think some DUM-DUM or similar putty would be a good idea to keep the water out.
Old 02-04-2012, 12:30 AM   #3
Roadster62
Roadster62's Avatar
I'd check to see if the wood blocks are in the inside that prevent dimpling the cowl when you tighten the bracket bolt.
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 02-04-2012, 10:14 AM   #4
Ray64
Ray64's Avatar
Tom,i havent heard of DUM DUM for years. Lol
Ray64 is offline   Reply With Quote
Old 02-04-2012, 10:17 AM   #5
Tom Wesenberg
I used DUM DUM a lot in the 70's when I was installing aftermarket air conditioners in cars. I haven't looked for it for a long time, but it should still be around.
I wonder if plumber's putty would work. I was rewiring an old Coke machine for a friend a couple weeks ago and we went to the local hardware store to buy some plumber's putty to replace the dried up stuff covering where the wires exit the cooling box.
