Old 01-20-2012, 12:53 PM   #1
TD
TD's Avatar
Default help with my crank
Here are some pic's of the only bad spot I found in my lower end. The crank shaft is mint here. There is a small devit and a scruffy spot slightly discolored. If you scrape it with your fingernail it is slightly course, not bad. The divit is small but easily felt. The motor was rebuild, run for a few months and put up for 40+ years till now. All else is nice. Should I open the can of worms and go after this piece or put the bad boy together knowing it will have good oil to lube with?
TD is offline   Reply With Quote
