Old 12-22-2011, 08:19 PM   #1
35 Ford
35 Ford's Avatar
Default What lubricant for window and latch parts?
I cleaned up the window regulator and door latch today. What lubricant should I use on the latch and the regulator? A spray silicone or a grease? None?
I plan on painting the parts as well. The regulator had paint on it before but the latch did not appear to have paint. I assume its ok to paint these parts?
Thanks!
My 35 Ford Pickup Blog
35 Ford is offline   Reply With Quote
Old 12-22-2011, 08:41 PM   #2
paul2748
paul2748's Avatar
Default Re: What lubricant for window and latch parts?
I use regular wheel bearing grease. I figure if it can stand up to wheel bearings, things like door latches and mechanisms are a breeze.
Old 12-23-2011, 12:41 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
I use spray white lithium --it is thinned, will penetrate, then the solvent evaporates leaving the grease ---that way it goes into the pivots and under the moving parts better
Old 12-23-2011, 06:42 AM   #4
51 MERC-CT
51 MERC-CT's Avatar
Just a suggestion on painting. Consider using self etching primer as final color (does not have to be topcoated ). It leaves a satin finish and if you want a glossy finish, coat with Rustoleum clear lacquer.
Old 12-23-2011, 08:29 AM   #5
G.M.
White Lubriplate was what was used in the 40s and 50s. G.M.
www.fordcollector.com
Old 12-23-2011, 01:47 PM   #6
Marv
Marv's Avatar
I use Lubriplate also. Marv
Marv is offline   Reply With Quote
Old 12-29-2011, 09:54 AM   #7
35 Ford
35 Ford's Avatar
Thanks for the suggestions fellows!
