I bought a 1934 Ford that comes with a lot of extra parts. This heater, which appears either NOS or restored, came with it. Has anyone ever seen one? It says "remove for summer driving". I do not know if it is a factory option or simply aftermarket.
Thee Inland Emperors |
I have no idea what it is, but it looks very interesting.
More pics please! -W
#3 | |
![]() Quote:
Thats all I have right now, I do not have the car yet.
Most likely aftermarket.
Paul in CT |
I have one on my 1935 Ford. The heat exchanger replaces the right exhaust manifold and the peice you are holding covers it. It picks up engine fan air and goes through a metal inlet in the firewall. Model A used the same setup. Mine was made by Atlas company.
Them old guys knew what they were doing.
-W
The Ford supplied ones had the heat exchanger below the stock right manifold in a muffler-like can that replaced the crossover pipe assembly and a sort of snorkel-looking tube that ran up front of engine to capture the blast of air from the fan to move air through the exchanger. Later Ford ones used an electric blower in the rig. There are a LOT of versions, with a lot of hookups to front compartment and some accessory hookups to blow into rear...
There is one for sale on Ebay if you want to look another variation. Says it is for 33 and 34.
That is not a Ford accesary heater for 33-34. It is a after market heater. The Ford heaters were made by Novi Corpration.
Here is a original 1933 1934 Ford Heater brochure. It shows some very nice views of the manifold, air inlet pipe, and the floor vent.
Bill Monzo |
This one is on ebay right now. It not the same but close
When will I be old enough to know better? ![]() |
#13 |
I saw one a while ago on ebay that was made by Sunday Manufacturing, they were asking $400 for a NOS. I think it was for a 35/36 and I think I read somewhere that some guy would reproduce one for you.I wonder if anyone might have plans for one, I think I could build one I need one for my 36.
#14 |
![]() That one is for a Model A
#15 |
Never seen one, but I bet it works well. We know flatheads produce a lot of heat.
#16 |
Yes it is for a Model A. If you keep your eye on ebay,there are 4 on there now. The later model ones do show up from time to time. If someone wanted to make one,here's a veiw of another style cut off. This part was mounted in the firewall of the car. It could be opened with cables or closed for the summer by hand.
#17 |
Here are some photos of the floor vent that was correct for the 1933 1934 Ford factory accessory heater. It was made of cast iron and very heavy. The front grill is pressed steel.
Bill Monzo |
#18 |
Nice piece. Ed
