Old 08-12-2025, 09:48 AM   #1
oldford
Default What is thread size on a 1931 rear axle that hub bolts to.
Would like to find a die to chase the threads on a 31 rear axle. Over time the threads have been hit and need to chase then with a die. Know where I can purchase a die, thanks.
oldford is offline   Reply With Quote
Old 08-12-2025, 10:16 AM   #2
Joe K
Joe K's Avatar
Default Re: What is thread size on a 1931 rear axle that hub bolts to.
You don't necessarily want a die. Using a die removes material on a thread that likely was made slightly "oversize" and to match the mating nut.
The threads were originally "rolled" to take advantage of the "grain" of the metal for strength. Cutting the thread removes/interrupts the grain and weakens the thread.
Instead you need to "reform" (press) the thread using a tool made for the purpose. Picture of this tool below. They appear on Ebay on occasion and if you are part of a club or have "contacts" someone may be able to help.
At least three seen on Ebay currently ranging in price from $23 to $49. Search term "antique thread restorer."
Joe K
Shudda kept the horse.
Joe K is online now   Reply With Quote
Old 08-12-2025, 10:19 AM   #3
Will N
Will N's Avatar
What Joe K said. But the thread size is 5/8-18
Will N is online now   Reply With Quote
Old 08-12-2025, 10:24 AM   #4
Bob C
This is the correct tool to chase the threads on an axle.
Start at the good threads and work out to the end of the axle.
https://www.ebay.com/itm/33606389231...NKKAZZ2DXRJTPF
Old 08-12-2025, 02:59 PM   #5
Phil Brown
Phil Brown's Avatar
Yes 5/8-18, but also many back in the day were "fixed"by recutting to 9/16-18 so watch for that
Phil Brown is offline   Reply With Quote
Old Yesterday, 06:52 AM   #6
Bruce of MN
Bruce of MN's Avatar
If it is still stock, you could use one of these:
https://www.langtools.com/sku-51-264...ng-die-5-8-18/
Old Yesterday, 10:40 AM   #7
Joe K
Joe K's Avatar
Keep in mind that if the tool involves removal of metal - then you probably don't want to use it - my comment above.
There are more modern "thread reforming tools" that are probably available in a cardboard hung "bubble" at your local auto support store. Pictured below.
Joe K
