Old 06-08-2025, 05:23 AM   #1
54mainline
Default Leaking head gasket
I’ve got a 1954 Mainline with a 239 Yblock. Over the winter, I had the heads and deck machined. Yesterday, I finished the assembly, started her up and let her run for about 15 seconds. Afterwards, I noticed coolant weeping out of the head gasket on the drivers side above the oil filter.
Additional information that might be useful: I used the Felpro embossed metal head gaskets (dry) and head bolts were torqued to 75ft-lbs (spec) torqued in a clockwise pattern from center out. I have no leaks anywhere else.
I’m curious what advice this group has for my next steps.
54mainline is offline   Reply With Quote
