I have a large logo 97 that looks like it has been rebuilt sometime in the past due to how clean it is and it looks like it has been yellow dichromate refinished. However, upon disassembly I noticed that the bottom part of the venturis where it slides into the cast iron base has corroded at some point and is partially missing. See attached pictures .
I have read that some say that the main body of this is junk and needs to be replaced because of this. Does this affect the function of the carb so much that it will no longer at least work”o.k.”? Would this kind of defect cause it to run rich and foul the spark plugs because it somehow messes up the vacuum signal in the venturis? I have read, but don’t exactly remember, I know it causes some sort of disturbance in the air flow through the carb. What happens if the choke butterfly assemblies are removed? Last edited by rhpope; 04-05-2025 at 05:44 AM. |
im no expert, maybe uncle max will look in but that dont look good and certainly cant be helping
#3 | |
![]() Quote:
Thats junk. Max may have the part for you, here's what they look like when Max works them over...
I have one that’s like that. Been running it for 25 years.Cant say that it’s ever caused a problem. Give it a try and see if it works or not.
Should be ok, try it. Do make sure none of the pieces are loose and can fall off. See if you can find the length of the skirts and if yours are long cut or grind yours down
If it runs rich the float level could be high.
How to set float uncle max. https://www.fordbarn.com/forum/showthread.php?t=171271 John
Welcome each day |
I would worry that some would fall off. I would trim the thin stuff off. Should work fine.
#11 | |
![]() Quote:
JB Weld is fuel-proof once it fully sets and stabilizes.
"My Model A... work never ends, only the day ends!" |
The carb bodies are not that hard to find . . . if it was mine, I'd just find a better one. But, hey . . . I'm a bit of a perfectionist.
