Old 02-16-2025, 10:33 PM   #1
headonz
headonz's Avatar
Default Magnet in sump ?
My B motor rebuild is coming along slowly , getting converted to shell bearings , 6.1 head ect .
I have been thinking about putting strong magnets in the engine sump and gearbox and diff to collect all those metal bits that seem to appear over time.
Is this thought to be a good idea.I have to imagine this has been done before magnetic sump plugs were a thing , just wondered about any draw backs ?
headonz is offline   Reply With Quote
Old 02-16-2025, 11:16 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Magnet in sump ?
I have magnetic drain plugs in my transmission, Mitchell O/D and rear end. In the engine most of the metal that wears is non-ferrous but it can't hurt to put a magnetic drain plug in..
Old 02-16-2025, 11:19 PM   #3
J Franklin
J Franklin's Avatar
I use magnitic drain plugs as well. I made them by boring a depression in the plug and epoxying a round magnet.
Old 02-17-2025, 07:41 AM   #4
nkaminar
nkaminar's Avatar
The magnet cannot hurt. Added to the drain plug means you can clean it during an oil change. The best protection is a full flow oil filter.
Old 02-17-2025, 09:37 AM   #5
Wick
Wick's Avatar
I put a magnet on the bottom of the gas tank, even have one on the Cub tractor.
Wick is offline   Reply With Quote
Old 02-17-2025, 12:50 PM   #6
katy
katy's Avatar
I put a magnet on the outside of the oil pan, opposite the oil pump. Then remove it just before draining the oil.
Old 02-17-2025, 02:45 PM   #7
nkaminar
nkaminar's Avatar
One of those strong super magnets on the outside of the filter may work best. I think I will do that.
Old 02-17-2025, 07:29 PM   #8
Y-Blockhead
I bought some of these magnets from Amazon. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I swear they are the strongest magnets I have come across. I can't even pull them apart. I have already given myself blood blisters a couple of times when they snapped together!!
Old 02-17-2025, 10:36 PM   #9
headonz
headonz's Avatar
On the outside is something I hadn't thought of ..... BUT
"Heat is bad for them. Some or all holding power is lost above the maximum "working temperature".
For N42 type "...80°C is the maximum operating temperature."--kjmagnetics
Something I did not know about magnets.
Old 02-17-2025, 11:51 PM   #10
Phil Brown
Phil Brown's Avatar
Did you know that steel when heated to 1417° F will also lose its magnetic properties
Phil Brown is offline   Reply With Quote
Old 02-18-2025, 04:55 AM   #11
ronn
and gold and copper around 2100 and plat goes to 3000
Old 02-18-2025, 08:17 AM   #12
Fullraceflathead
Fullraceflathead's Avatar
Nickel I believe loses it's magnetic around 417° and it returns as it cools!!!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 02-18-2025, 08:29 AM   #13
Y-Blockhead
Gold and copper are magnetic? Something
I never experienced… Do you need a special magnet for them??
Old 02-18-2025, 09:20 AM   #14
johnneilson
Originally Posted by Y-Blockhead View Post
Gold and copper are magnetic? Somethinp I never experienced… Do you need a special magnet for them??
Yes special magnet required
Usually identified with diamonds accompanied
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 02-19-2025, 01:33 AM   #15
headonz
headonz's Avatar
You mean like a puddle
Do you have a larger image of your avatar photo ?
Old 02-19-2025, 07:12 AM   #16
nkaminar
nkaminar's Avatar
Best to use the magnets that only have a north pole. If you find one, apply for a Nobel prize.
Old 02-19-2025, 10:26 AM   #17
JayJay
I epoxy these little dudes into pieces of hardwood to make wood jaw vise inserts for holding sensitive items. I’ve also used them to hold patch panels in place for butt welding. Lots of uses around the shop.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 02-19-2025, 12:01 PM   #18
Phil Brown
Phil Brown's Avatar
A puddle of steel would be 2500°F - 2700°F depending on its amount of carbon content
1417°F is just nice and red. Fahrenheit or as we know it "freedom units not communist units
Old 02-20-2025, 03:58 AM   #19
headonz
headonz's Avatar
Good find.I hope its being well cared for.I think it may have a little more paint on it than mine
Old 02-20-2025, 11:09 AM   #20
Phil Brown
Phil Brown's Avatar
Attachment 561133Attachment 561134
Thank you, the car was purchased new in Virginia by a young man who then drove it to California. He joind the Navy and became a coreman (doctor) When he got out of the navy he stayed in San Diego where he started his private practice as a doctor using the coupe for his house calls around San Diego's Point Loma area. In 1973 or 1974 he quit driving due to his age then and the family parked it on some property they have east of San Diego where it sat until I purchased it in 2022.
The picture is where it sat for the last 50 years
