Magnet in sump ? My B motor rebuild is coming along slowly , getting converted to shell bearings , 6.1 head ect .
I have been thinking about putting strong magnets in the engine sump and gearbox and diff to collect all those metal bits that seem to appear over time. Is this thought to be a good idea.I have to imagine this has been done before magnetic sump plugs were a thing , just wondered about any draw backs ? |
Re: Magnet in sump ? I have magnetic drain plugs in my transmission, Mitchell O/D and rear end. In the engine most of the metal that wears is non-ferrous but it can't hurt to put a magnetic drain plug in..
Re: Magnet in sump ? I use magnitic drain plugs as well. I made them by boring a depression in the plug and epoxying a round magnet.
Re: Magnet in sump ? The magnet cannot hurt. Added to the drain plug means you can clean it during an oil change. The best protection is a full flow oil filter.
Re: Magnet in sump ? I put a magnet on the bottom of the gas tank, even have one on the Cub tractor.
Re: Magnet in sump ? I put a magnet on the outside of the oil pan, opposite the oil pump. Then remove it just before draining the oil.
Re: Magnet in sump ? One of those strong super magnets on the outside of the filter may work best. I think I will do that.
Re: Magnet in sump ? Quote:
On the outside is something I hadn't thought of ..... BUT "Heat is bad for them. Some or all holding power is lost above the maximum "working temperature". For N42 type "...80°C is the maximum operating temperature."--kjmagnetics Something I did not know about magnets. |
Re: Magnet in sump ? and gold and copper around 2100 and plat goes to 3000
Re: Magnet in sump ? Nickel I believe loses it's magnetic around 417° and it returns as it cools!!!
I never experienced…:eek::eek: Do you need a special magnet for them?? |
Usually identified with diamonds accompanied J |
You mean like a puddle :D Do you have a larger image of your avatar photo ? |
Re: Magnet in sump ? Best to use the magnets that only have a north pole. If you find one, apply for a Nobel prize.
Re: Magnet in sump ? 1 Attachment(s)
1417°F is just nice and red. Fahrenheit or as we know it "freedom units not communist units :D |
Re: Magnet in sump ? 2 Attachment(s)
Good find.I hope its being well cared for.I think it may have a little more paint on it than mine :D
Attachment 561133Attachment 561134 |
The picture is where it sat for the last 50 years |
