Old 09-07-2010, 09:20 PM   #1
custom53
custom53's Avatar
Default 31 slant windshield cowl question
how far back do the windshield posts tilt back? i am making a tudor slant windshield sedan and i want it to look right. i am using a 32 header also. any help would be great.
custom53 is offline   Reply With Quote
Old 09-07-2010, 10:31 PM   #2
Bruce Adams
Bruce Adams's Avatar
Default Re: 31 slant windshield cowl question
Do these help?
Photos of my 68C late 1931 Cabriolet.
Bruce Adams is offline   Reply With Quote
Old 09-07-2010, 11:55 PM   #3
Roadster62
Roadster62's Avatar
Its been done on a Vicky and 28-29 Coupe, post the question over on the HAMB.
Roadster62 is offline   Reply With Quote
Old 09-08-2010, 07:07 AM   #4
allen
allen's Avatar
Send a message via ICQ to allen
A Vicky is a slant
allen is offline   Reply With Quote
Old 09-08-2010, 05:53 AM   #5
Kevin in NJ
I believe 4 degrees if I recall correctly.
Old 09-08-2010, 09:09 AM   #6
Jason in TX
Jason in TX's Avatar
He means that DRuss32 put a 32 header on a Model A Vicky over on the HAMB.
Here is the link: http://www.jalopyjournal.com/forum/s...d.php?t=321771
The 28-29 coupe is Brian Bass' coupe.
Here is the link: http://www.jalopyjournal.com/forum/s...=104217&page=2
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 09-12-2010, 07:57 AM   #7
custom53
custom53's Avatar
mine is a 30 cowl with straight windshield posts. i want to modify the posts to slant them back. kevin in nj said it is 4 degrees, how far back it that in inches? from what i can tell in pictures it is about 3 or 4 inches. i just want it to look right.
Old 01-01-2025, 06:56 PM   #8
jwmckenzie
Originally Posted by custom53 View Post
..... how far back it that in inches?
Trigonometry is your friend. If you know the angle (10 degrees) and the height of the windscreen you can find 'how far back in inches?'. Here is a calculator online.
https://www.calculator.net/right-tri...alculator.html
If you post the height of the windscreen. I can calculate it for you.
jwmckenzie is offline   Reply With Quote
Old 01-03-2025, 12:31 PM   #9
JRrev
JRrev's Avatar
14+years ago?
JRrev is offline   Reply With Quote
Old 09-12-2010, 08:08 AM   #10
Kevin in NJ
When doing mod work it is partially engineering and partially playing to get it to look right. The correct angle is the angle you make everything work together easily and it may not be the angle you think.
There is a lot of mock up and then stand back to make sure it looks and fits right. I would think you need to make the cuts and tack weld everything together and then stand back to see it it works. You really need to do a functional mock up with it solidly tacked together to make sure windows and doors work. Keep in mind the original window channels may not work as well with glass that is tapered at the front edge. Look at how the real slant doors did the window glass. They changed to a two arm regulator that would keep the glass level. The straight window cars used two parallel channels and a single arm regulator to keep the glass level.
Not sure how all the cowls measure out. Keep in mind the slant window windshield frame was an inch or two (I can not remember) lower. You are not really comparing apples to oranges.
Old 12-31-2024, 10:38 PM   #11
28av8nut
Fordor posts are 10degrees according to some promotional ford leaflets I have.
28av8nut is offline   Reply With Quote
Old 01-01-2025, 09:08 AM   #12
JayJay
It’s more than just the windshield slant. Doors are two hinge, not three, the front portion of the side window channel gets moved aft to accommodate the slant (unless you also cut the top of the side window back?), that would impact the window regulator… an interesting project to be sure, but a lot of work.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 01-01-2025, 09:19 AM   #13
Bob Bidonde
Bob Bidonde's Avatar
The window slant angle is 10 degrees.
Bob Bidonde
