The Ford Barn
-   -   31 slant windshield cowl question (https://www.fordbarn.com/forum/showthread.php?t=12950)
custom53 09-07-2010 09:20 PM
how far back do the windshield posts tilt back? i am making a tudor slant windshield sedan and i want it to look right. i am using a 32 header also. any help would be great.
Bruce Adams 09-07-2010 10:31 PM
Re: 31 slant windshield cowl question
3 Attachment(s)
Do these help?
Photos of my 68C late 1931 Cabriolet.
Roadster62 09-07-2010 11:55 PM
Its been done on a Vicky and 28-29 Coupe, post the question over on the HAMB.
Kevin in NJ 09-08-2010 05:53 AM
I believe 4 degrees if I recall correctly.
allen 09-08-2010 07:07 AM
A Vicky is a slant
Jason in TX 09-08-2010 09:09 AM
He means that DRuss32 put a 32 header on a Model A Vicky over on the HAMB.
Here is the link: http://www.jalopyjournal.com/forum/s...d.php?t=321771
http://i99.photobucket.com/albums/l3...s/P1050011.jpg
The 28-29 coupe is Brian Bass' coupe.
Here is the link: http://www.jalopyjournal.com/forum/s...=104217&page=2
http://pic3.picturetrail.com/VOL19/1.../134686367.jpg
custom53 09-12-2010 07:57 AM
mine is a 30 cowl with straight windshield posts. i want to modify the posts to slant them back. kevin in nj said it is 4 degrees, how far back it that in inches? from what i can tell in pictures it is about 3 or 4 inches. i just want it to look right.
Kevin in NJ 09-12-2010 08:08 AM
When doing mod work it is partially engineering and partially playing to get it to look right. The correct angle is the angle you make everything work together easily and it may not be the angle you think.
There is a lot of mock up and then stand back to make sure it looks and fits right. I would think you need to make the cuts and tack weld everything together and then stand back to see it it works. You really need to do a functional mock up with it solidly tacked together to make sure windows and doors work. Keep in mind the original window channels may not work as well with glass that is tapered at the front edge. Look at how the real slant doors did the window glass. They changed to a two arm regulator that would keep the glass level. The straight window cars used two parallel channels and a single arm regulator to keep the glass level.
Not sure how all the cowls measure out. Keep in mind the slant window windshield frame was an inch or two (I can not remember) lower. You are not really comparing apples to oranges.
28av8nut 12-31-2024 10:38 PM
Fordor posts are 10degrees according to some promotional ford leaflets I have.
JayJay 01-01-2025 09:08 AM
It’s more than just the windshield slant. Doors are two hinge, not three, the front portion of the side window channel gets moved aft to accommodate the slant (unless you also cut the top of the side window back?), that would impact the window regulator… an interesting project to be sure, but a lot of work.
Bob Bidonde 01-01-2025 09:19 AM
The window slant angle is 10 degrees.
jwmckenzie 01-01-2025 06:56 PM
Originally Posted by custom53 (Post 77320)
..... how far back it that in inches?
Trigonometry is your friend. If you know the angle (10 degrees) and the height of the windscreen you can find 'how far back in inches?'. Here is a calculator online.
https://www.calculator.net/right-tri...alculator.html
If you post the height of the windscreen. I can calculate it for you.
JRrev 01-03-2025 12:31 PM
14+years ago?
