Old 11-30-2024, 02:23 PM   #1
chevy43
chevy43's Avatar
Default Need help with headlight and ignition switches in column
None of my trucks have the origianal switches in the column hooked up. I don't have any information on how to work on them. Are they so problematic they aren't worth woking on?
chevy43 is offline   Reply With Quote
Old 11-30-2024, 04:51 PM   #2
Kube
Kube's Avatar
Default Re: Need help with headlight and ignition switches in column
It may help to tell us what year, model, etc. you are enquiring about.
Kube is online now   Reply With Quote
Old 11-30-2024, 05:09 PM   #3
chevy43
chevy43's Avatar
33 and 34 BB truck and 35 model 51 truck.
Old 11-30-2024, 07:14 PM   #4
Bob C
Do you have the switch at the bottom of the column or is it missing?
Old 12-01-2024, 07:32 AM   #5
Terry,OH
Terry,OH's Avatar
Also need the horn rod which has to be straight. Most problems come from bent or deformed horn rods which will sometimes turn the lights ON or OFF when the steering wheel is turned. Otherwise not much problem.
Old 12-02-2024, 05:28 PM   #6
sugarmaker
sugarmaker's Avatar
Chevy43.
i did a back yard job rebuilding my egg at the bottom of the 32 steering column. Just took some time and patience. I think my wire coming down for the horn was intact. I did not have to play with the items on the steering wheel. Give us some pictures and what is your goal.
Regards,
Chris and Cheryl
1932 AAB Truck
1953 Ford Jubilee
1965 Mercury Comet Caliente
2015 Ford F250 SuperCrew
Lots of Allis tractors
Some Cub Cadets
Old 12-02-2024, 08:04 PM   #7
Model51
Model51's Avatar
Also, the wiring harness needs to have the switch plate attached. The switch plate with wires goes inside the sheet metal container on the bottom of the steering box. The light switch rod spins a contact disc making contact with the wiring harness to make the lights work.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 12-05-2024, 09:05 AM   #8
Terry,OH
Terry,OH's Avatar
Does your column lock, prevent the steering wheel from turning? If so It would appear the column drop has many of the parts necessary for the original ignition switch to work.
