Old 11-15-2024, 11:14 PM   #1
Newc
Newc's Avatar
Default rebuilt 8ba with only 4 'flywheel holes- no dowels
Automatic crank?? old Tam eng Ford rebuild. No dowel holes and checking for pilot bushing hole ?Customers eng. Newc
Old 11-16-2024, 07:59 AM   #2
KiWinUS
KiWinUS's Avatar
Default Re: rebuilt 8ba with only 4 'flywheel holes- no dowels
Pilot bushing or bearing is in flywheel not crank.
Old 11-16-2024, 08:44 AM   #3
V8 Bob
V8 Bob's Avatar
I've read that some late Merc cranks with factory fitted auto trans were not "dimpled" for manual trans input shafts in the flange, but no knowledge about dowel holes being removed also.
Old 11-16-2024, 08:52 AM   #4
cadillac512
cadillac512's Avatar
If the flywheel is still installed it'll look like it has no dowels since the tin cover hides them. Maybe not your situation but thought I'd mention it.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 11-16-2024, 03:58 PM   #5
Bored&Stroked
Bored&Stroked's Avatar
I've seen 4" Merc cranks that were NOT setup for manual trans. I've never seen a crank without the dowel pins.
Old 11-16-2024, 06:23 PM   #6
Newc
Newc's Avatar
Final word from customer: corrected missing idea. Needed a smarter better inspection- all ok thanks fellows. Newc
