Old 07-21-2024, 07:13 AM   #1
Wallysdog
Default Photo of brake line hookup on a 1950 Custom...
Howdy!
Would anyone have a photo of how the brake lines and pressure switch hook up to the master cylinder banjo on a 1950 Ford Custom.
I received a set of brake lines from Inline and I am having problems with how they are run.
Thanks.
Wallysdog is offline   Reply With Quote
Old 07-22-2024, 08:48 AM   #2
Shoebox
Shoebox's Avatar
Default Re: Photo of brake line hookup on a 1950 Custom...
Here is a pic of that spot on my '51 Tudor. FWIW all the hard lines are from Inline Tube. Hope this helps.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 07-22-2024, 12:49 PM   #3
Bruce_MO
My recollection is fuzzy, because I got rid of my ‘51 several years ago, but I think my brake light switch screwed into the head of the bolt that’s retaining the brass fitting. So the head of the bolt was drilled and tapped, and narrowed down to a smaller diameter where it passes thru the fitting. Just the two brake lines screwed into the brass fitting.
It was years ago that installed a new master cylinder, so my recollection could be off.
Bruce_MO is offline   Reply With Quote
Old 07-23-2024, 06:24 PM   #4
Wallysdog
That's perfect, thanks for the picture. It went together with a little torqing, swisting and cussing, but I got her done. I have one brake line left in the box. I think they threw that in to confuse me, or it goes with another configuration. Thanks again.
Jim-
Old 07-23-2024, 06:53 PM   #5
19Fordy
19Fordy's Avatar
Wally, be sure to apply brake fluid to the threads BEFORE you screw in the line to the fitting.
Old 08-02-2024, 07:06 PM   #6
josels
Thanks for the tip 19Fordy.
josels is offline   Reply With Quote
