The Ford Barn
-   -   Photo of brake line hookup on a 1950 Custom... (https://www.fordbarn.com/forum/showthread.php?t=340501)
Wallysdog 07-21-2024 07:13 AM
Howdy!
Would anyone have a photo of how the brake lines and pressure switch hook up to the master cylinder banjo on a 1950 Ford Custom.
I received a set of brake lines from Inline and I am having problems with how they are run.
Thanks.
Shoebox 07-22-2024 08:48 AM
Re: Photo of brake line hookup on a 1950 Custom...
1 Attachment(s)
Here is a pic of that spot on my '51 Tudor. FWIW all the hard lines are from Inline Tube. Hope this helps.
Bruce_MO 07-22-2024 12:49 PM
My recollection is fuzzy, because I got rid of my ‘51 several years ago, but I think my brake light switch screwed into the head of the bolt that’s retaining the brass fitting. So the head of the bolt was drilled and tapped, and narrowed down to a smaller diameter where it passes thru the fitting. Just the two brake lines screwed into the brass fitting.
It was years ago that installed a new master cylinder, so my recollection could be off.
Wallysdog 07-23-2024 06:24 PM
That's perfect, thanks for the picture. It went together with a little torqing, swisting and cussing, but I got her done. I have one brake line left in the box. I think they threw that in to confuse me, or it goes with another configuration. Thanks again.
Jim-
19Fordy 07-23-2024 06:53 PM
Wally, be sure to apply brake fluid to the threads BEFORE you screw in the line to the fitting.
josels 08-02-2024 07:06 PM
Thanks for the tip 19Fordy.
