I bought a 1930 Tudor (three door) 9 months ago and have been working to get it reliable. It drove well on the test drives and subsequent drives with the exception of shifting very hard...no shifts without a lot of grinding even double clutching and on flat roads...until a manifold gasket started to leak and I put it away for the winter. I did replace the bendix (US made original style) once after suspecting that was a starting problem in Spring only to find that it was inadequate grounding of the battery. At the 7 month point I drove it in a two day rally that took it through 300 km of steep hills and hairpin curves....quite an eye opener regarding how much work it is to drive/steer in those conditions and a real test of how much of a challenge to use the brakes early and often as well as getting enough RPM to keep enough steam to make it up the next hill without grinding a pound of gears to downshift to 2nd. Serious second thoughts about whether this is the classic car for me. At a fuel stop on the way home the car would not start and started giving that characteristic electric drill sound telltale of a starter/bendix problem. An ADAC (German AAA) push start got me home and into my barn/workshop only to find the flywheel side bolt of the bendix missing. I do not have a lift and dropping the transmission while the car is up on jacks did not appeal to me. I am getting a bit stiff in my old age. I had it towed to a reputable classic car mechanic who dropped the transmission only to find not one missing bolt...but THREE lodged in the transmission. The mechanic was quite surprised that nothing catastrophic had happened while driving. I am the fourth owner and the previous owner had it for less than a year and did zero work on the car so that means that the other two bolts dropped and were replaced while in the hands of the one who restored it after 47 years in a barn. He sold it off so that his wife would not be stuck with it while he died of cancer, so he is not around to ask. It seems that the traditional bendix is a serious problem for this car and I am not up for taking it to a specialist when the bendix self-destructs every few months. Now I am looking at an alternative. Meeting with the mechanic in a couple of days to discuss an alternative starter system. Any suggestions? I like the car as original as possible but will not be showing it. It needs to be reliable to make it worth owning as a sunny weekend tourer for 100 or so km. Is this perhaps a time to shift to 12V and a modern stater, alternator, coil, etc? Seems the12v switch should be manageable for about $1200-$1500.
It’s in the installation,not using worn parts,the bolts can’t be worn and loose in the threads,the flywheel teeth have to have proper shape along with the pinion gear .
the locks have to be new each time, the bolts tight,the spring tight and not distorted, 45 years untouched on my car,has survived driving out of the garage on the starter,starting in gear many times when the clutch was stuck etc. First starter I rebuilt 50 years ago,original to the car the original generator has be more reliable than the chevrolet alternator in my truck (3 rebuilds in 40 years) |
Just went through that nightmare. My USA made Bendix failed after
2 starts. The bolts they used were wrong. The back bolt was so poorly installed, it completely popped out. Both the Modern Bendix & original style USA made drive are not made any more. I bet when you fish out the bolts or bolts, one will be not broken. You should either use a shop vacuum or a magnet to fish out the remains.
1928 Roadster Pickup 1930 Tudor 1943 Ford WWII Jeep 1968 Taco Minibike Member, Santa Anita Model A's Arcadia Ca. |
What Kurt in NJ said X2... original starter un-touched in my 31' for the past 50 years. I was a high school kid, put it together from as found used original Ford parts. I guess that I must have done it right!
Good to hear from you.... I hope that you can get the problems straightened out, there in Germany. Joe B |
Nothing wrong with the original 6 volt system! Just make sure all components are OEM quality (you may need to find good used stuff). Make sure the ring gear is installed correctly (bevel to the rear). If the threads in the shaft for the Bendix bolt are worn, the bolt will not stay tight.
On the hard shifting, make sure the clutch releases completely. With the pedal held down and the engine idling in neutral, the gears must coast to a stop after a few seconds and you can shift into gear without grinding. The disc may be dragging against the flywheel and pressure plate. Make sure the trans has the right gear oil (too thin can cause grinding). Also, there are parts available to convert the original trans to synchronized 2nd and 3rd gears. |
#6 | |
Do you know what the parts are needed for the synchronized 2nd and 3rd gears? Last edited by old31; 06-19-2024 at 03:44 PM. |
X-2,3 on posts 2 & 4 , if you think about it ??? How have these 90 + year olds make it into this century !!!!! Most here that post with problems have modified parts !!!! Most with non- modified usually do post with problems. IMHO
see this page:
https://modelastore.com/index.php?ro...arch=bendix%20 1. A-11375-D Starter Bendix Spring- For 3/8" Bolts ( there is a 5/16ths version BOLT also). $12.50 MUST USE this spring. The Model T spring looks similar but coil is wound wrong way The V8 looks similar and is wound the wrong way. Other manufacturer Bendix springs are not likely to work correctly. 2. A-11377-D Starter Bendix Bolt Set- 3/8 inch $5.50 Each bolt is for a special location. New lock washers MUST be used each time and be installed correctly. Hardware store bolts will not last very long. (too soft and shanks are wrong) The bolts MUST be installed in correct position on Bendix and can not be interchanged. 3. A-11384 BENDIX KEY FOR STARTER DRIVE A-11384 Bendix Key For Starter drive Availability: In Stock $0.30 Key way must be correct size and shape. (Again hardware store keyway may or may not work. Bendix with correctly installed parts will work for a long time. The 6 volt starter in my coupe IS same one that was in the car when we bought it in 1962. More than 60,000 miles since then. This car has been used in a delivery operation with more than 4,000 ( start / shut down cycles) for the last 15 years The only problem was 20 years ago the spring broke. Wrong parts installed cause MANY problems. Last edited by Benson; 06-19-2024 at 12:49 PM. |
I lost a bolt off of my bendix and can't find it with a magnet. Will I be okay to
drive it with that bolt laying in there. |
Tom OHIO,
Until it gets jammed in the flywheel. |
Yes that had me nervous. I went today and bought me a new flexible magnet and I got the bolt and the washer out.
#13 | |
![]() Quote:
#14 | |
![]() Quote:
and put a smaller hose in it and luckily, I got it out. The smaller hose I used was about 3/4" ID. The size is a little critical because it has to be big enough to grab the bolt but small enough to push the hose all the way down to the area where it is. I have even heard of people putting magnets onto the flywheel and hand cranking to get it. I choose the vacuum method as I didn't want something like that falling off for some reason and causing more trouble. If you play with it long enough, you'll probably get it. Dino F.
#15 |
Put a strong magnet onto the flywheel, and turn the engine over slowly by hand. as the magnet goes around you should hear the magnet pick up the bolt and one the magnet get to the starter opening remove both of them.
#16 |
With the starter removed, place a strong "rare-earth" magnet on the outer diameter of the flywheel...rotate the engine using your hand crank and when the maginet re-appears so will your bolt
#17 |
Y-Blockhead, I think Big Hammer left out the word “not”. As in, “Most with non-modified parts usually do NOT post problems.”
David in San Antonio Late ‘30 Deluxe "Wretched Roadster" Alamo A’s Club |
#18 |
#19 |
Proper restoration eliminates the need for most modifications.
#20 |
I have a modern Bendix in my car with no problems. The bolts are captured so they do not come out. See https://modelastore.com/index.php?ro...roduct_id=4110. That one is out of stock but it will give you an idea of what they are. As with any device, there are good ones and bad ones. The ones made in the USA are the best.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 06-17-2024 at 02:50 PM. |
