Old 03-05-2024, 06:43 PM   #1
53INGY
Default 6volt to 12volt conversion on a 53 Ford
I have several questions on how this conversion done properly I am looking at a car to buy with this conversion I understand they are changing the starter motor but I wonder about horns guages blower motor overdrive controls etc.the lights are easy change the bulbs I wish they the seller had left the 6 volt system alone would appreciate input on what to look for if go ahead with a purchase Thanks Ford barners
53INGY is offline   Reply With Quote
Old 03-05-2024, 07:28 PM   #2
19Fordy
19Fordy's Avatar
Default Re: 6volt to 12volt conversion on a 53 Ford
Take a look at this video and then call the company with your specific questions.
https://www.bing.com/videos/rivervie...9620&FORM=VIRE
The other option is to wait until the seller successfully, neatly and completely makes the 12V conversion and then you buy it as a fully working vehicle. That way you're not buying into a "project" you don't need.
Old 03-06-2024, 10:41 AM   #3
Scott52
I found this book helpful. Section on OD transmission, List bulb conversions. Simple and Short.
Scott52 is offline   Reply With Quote
Old 03-06-2024, 10:53 AM   #4
Zax40
Zax40's Avatar
I had a '53 that was converted to 12V. The horns need no change. The gauges can be made to work with voltage reducers. The blower motor can be replaced with a 12V one or you can have it rewound at a electric motor rebuilding shop. I didn't have overdrive, so i'm not sure on that part
Zax40 is offline   Reply With Quote
Old 03-06-2024, 11:05 AM   #5
Shoebox
Shoebox's Avatar
I just completed the conversion on my '51 Tudor. For the overdrive I purchased 12 volt relay and solenoid. What has been said about the other things is correct.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 03-06-2024, 11:29 AM   #6
Ol' Ron
Ol' Ron's Avatar
Converting to 12 v is a very good mover for most applications, but not necessary for a local use "OLD" car. The biggest advantage is::::: You can go anyplace with it. Done properly. I've done many, and never used a 12 converted starter. Always carried a spare, but never used it. I also install an in tank fuel pump, that solves the fuel system. and never use a belt driven fam, only electric. Convert the water pups with same pulleys for a one narrow belt Altinator drive / Modernizing the accessory drive on the engine also eliminates problens for long distant drive.
I could go on here and replace to trans to T170 and a8" ford rear This way you can use the original wheels and nobody will know Probably good for 110K with just general maintenance.
Old 03-06-2024, 12:15 PM   #7
petehoovie
petehoovie's Avatar
Old 03-06-2024, 12:59 PM   #8
pistonbroke
Like Ol Ron said the starter is one thing you don't have to change. I ran a six volt starter in my 55 bird for five years with no issues. Tim
Old 03-06-2024, 02:17 PM   #9
53INGY
Thanks Ford Barners for all the input on a 12v converted system I wonder how to obtain the book spoken by two you I would like to buy the 53 but I have a small slag the man I first spoke too on buying the car has since passed away so know I have to deal with a mechanic representing the family and the car is multiple states away the car has had several improvments which keeps my interest
Old 03-07-2024, 07:27 AM   #10
chap52
chap52's Avatar
Ran a 12 vt conversion on my "52 F1 for over ten years. Had the bendix break on the 6vt starter but it was the old one that came with the truck when it was new. A voltage drop on the gauges and all good to go. Chap
Old 03-07-2024, 11:49 AM   #11
Scott52
Randy Rundle website
http://www.fifthaveinternetgarage.com/index.php
Old 03-07-2024, 11:52 AM   #12
petehoovie
petehoovie's Avatar
Old 03-07-2024, 05:13 PM   #13
53INGY
thanks for the info on 12volt conversion book I have one ordered am sure I will do a conversion down the road even if the car I am bird dogging doesnt work out
Old 03-08-2024, 01:39 PM   #14
TJ
TJ's Avatar
There's a volt drop on the back of the early Mustang gauge panel that I have used for the volt drop for the gauges. It can be found on e-Bay or at some auto parts stores. The Motorcraft part # is GR-508. It's called an instrument cluster voltage regulator. Many of them listed on e-Bay for $25-$30.
