Old 04-03-2025, 10:38 AM   #1
34fordy
34fordy's Avatar
Default Reason or just for looks #2
Whazzit for?
34fordy is offline   Reply With Quote
Old 04-03-2025, 10:47 AM   #2
ActionYobbo
ActionYobbo's Avatar
Default Re: Reason or just for looks #2
Fuel coils induce more power
I am building a 1939 1 ton express
ActionYobbo is offline   Reply With Quote
Old 04-03-2025, 10:47 AM   #3
tubman
tubman's Avatar
Originally Posted by 34fordy View Post
Whazzit for?
Cooling the fuel before it gets to the carbs. Looks neat too!
Old 04-03-2025, 10:48 AM   #4
Tim Ayers
Copper lines can work harden from vibration. The coils act like a shock absorber. The coiling in the picture is a bit excessive, but that is one of the reasons its done.
Old 04-03-2025, 10:54 AM   #5
tubman
tubman's Avatar
Actually, probably all of the above, but I still say "cooling" because you don't need that many coils to dampen vibration. A lot of applications (including some very early automobiles) use "cooling coils" instead of radiators.
Old 04-03-2025, 10:56 AM   #6
petehoovie
petehoovie's Avatar
Whazzit for?
Old 04-03-2025, 01:42 PM   #7
Ronnieroadster
Ronnieroadster's Avatar
Speeds up the fuel entering the carb thus acting like a supercharging effect
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 04-03-2025, 03:36 PM   #8
Charlie Stephens
I must be missing something. Every car I have had has a higher temperature in the engine compartment than in the back where the tank is located. If anything it would be heating.
Charlie Stephens
Old 04-03-2025, 03:40 PM   #9
Charlie Stephens
Whazzit for?
It is an accident waiting to happen. The mass of the coils combined with vibration from the engine will result in the copper tubes cracking and spilling gas all over the engine.
Charlie Stephens
Old 04-03-2025, 04:00 PM   #10
ford38v8
ford38v8's Avatar
Charlie Stephens
Charlie, I respectfully disagree. Coils, although overkill in this case, tend to dampen vibrations as opposed to straight connections point to point without coils.
Alan
Old 04-03-2025, 07:23 PM   #11
paul2748
paul2748's Avatar
I agree - once the engine get up to temp it will heat all those coils.
Charlie Stephens
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-03-2025, 07:36 PM   #12
tubman
tubman's Avatar
The fan should keep a steady flow of air over the coils. Did you ever think about why automatic transmission coolers are in a lower radiator tank in a car with 195° thermostats? Cool is relative.
Plus, I never said it would work (but it probably does), just what I thought it was for.
Old 04-03-2025, 11:49 PM   #13
ThirstyThirty
ThirstyThirty's Avatar
I am wondering if all 3 coils come off a common fuel log?
"My Model A... work never ends, only the day ends!"
ThirstyThirty is offline   Reply With Quote
Old 04-04-2025, 08:13 AM   #14
pistonbroke
It's gotta work better then the clothes pins I've seen so often on the fuel lines to the carbi I did the coils like that out of new brake line once for my oil lines to and from the filtor for cooling . I never new if it worked or helped. Tim
