The Ford Barn
-   -   Reason or just for looks #2 (https://www.fordbarn.com/forum/showthread.php?t=348039)
34fordy 04-03-2025 10:38 AM
1 Attachment(s)
Whazzit for?
ActionYobbo 04-03-2025 10:47 AM
Re: Reason or just for looks #2
Fuel coils induce more power
tubman 04-03-2025 10:47 AM
Originally Posted by 34fordy (Post 2380973)
Whazzit for?
Cooling the fuel before it gets to the carbs. Looks neat too!
Tim Ayers 04-03-2025 10:48 AM
Copper lines can work harden from vibration. The coils act like a shock absorber. The coiling in the picture is a bit excessive, but that is one of the reasons its done.
tubman 04-03-2025 10:54 AM
Actually, probably all of the above, but I still say "cooling" because you don't need that many coils to dampen vibration. A lot of applications (including some very early automobiles) use "cooling coils" instead of radiators.
petehoovie 04-03-2025 10:56 AM
Whazzit for?
https://www.fordbarn.com/forum/attac...7&d=1743694659
Ronnieroadster 04-03-2025 01:42 PM
Speeds up the fuel entering the carb thus acting like a supercharging effect :D
Charlie Stephens 04-03-2025 03:36 PM
I must be missing something. Every car I have had has a higher temperature in the engine compartment than in the back where the tank is located. If anything it would be heating.
Charlie Stephens
Charlie Stephens 04-03-2025 03:40 PM
Whazzit for?
It is an accident waiting to happen. The mass of the coils combined with vibration from the engine will result in the copper tubes cracking and spilling gas all over the engine.
Charlie Stephens
ford38v8 04-03-2025 04:00 PM
Charlie Stephens
Charlie, I respectfully disagree. Coils, although overkill in this case, tend to dampen vibrations as opposed to straight connections point to point without coils.
paul2748 04-03-2025 07:23 PM
I agree - once the engine get up to temp it will heat all those coils.
Charlie Stephens
tubman 04-03-2025 07:36 PM
The fan should keep a steady flow of air over the coils. Did you ever think about why automatic transmission coolers are in a lower radiator tank in a car with 195° thermostats? Cool is relative.
Plus, I never said it would work (but it probably does), just what I thought it was for.
ThirstyThirty 04-03-2025 11:49 PM
I am wondering if all 3 coils come off a common fuel log?
pistonbroke 04-04-2025 08:13 AM
It's gotta work better then the clothes pins I've seen so often on the fuel lines to the carbi I did the coils like that out of new brake line once for my oil lines to and from the filtor for cooling . I never new if it worked or helped. Tim
