Old 07-26-2023, 06:43 PM   #1
38convsedan
38convsedan's Avatar
Default 38 vs 39 Deluxe Wooden Floor Boards
My 38 cs has 39 juice brakes…and 38 wooden floor boards!!
There are different part numbers for each year.
Are the brake and clutch openings different between 38 and 39?
Should I use 39 boards to accommodate the 39 clutch/brake pedals?
As always, thank you in advance!
Steve
38convsedan is offline   Reply With Quote
Old 07-27-2023, 02:29 PM   #2
ActionYobbo
ActionYobbo's Avatar
Default Re: 38 vs 39 Deluxe Wooden Floor Boards
My 39 truck with juice brakes has no holes in the floor. Have to lift the whole floor or work from the underside.
I am building a 1939 1 ton express
ActionYobbo is offline   Reply With Quote
Old 07-27-2023, 05:45 PM   #3
fordv8j
fordv8j's Avatar
we used 39 pedals on our 38 conv.-heated and bent to fit 38 floorboards, don't know if 38 and 39 are the same, mine had no floorboards, but I had a 38 pattern
fordv8j is offline   Reply With Quote
Old 07-27-2023, 06:39 PM   #4
TJ
TJ's Avatar
I suspect if you use the 39 boards you need to use the 39 standard boards.
Old 07-29-2023, 09:47 AM   #5
Kube
Kube's Avatar
No difference to the '39 deluxe.
