The Ford Barn
-   -   38 vs 39 Deluxe Wooden Floor Boards (https://www.fordbarn.com/forum/showthread.php?t=329146)
38convsedan 07-26-2023 06:43 PM
My 38 cs has 39 juice brakes…and 38 wooden floor boards!!
There are different part numbers for each year.
Are the brake and clutch openings different between 38 and 39?
Should I use 39 boards to accommodate the 39 clutch/brake pedals?
As always, thank you in advance!
Steve
ActionYobbo 07-27-2023 02:29 PM
Re: 38 vs 39 Deluxe Wooden Floor Boards
My 39 truck with juice brakes has no holes in the floor. Have to lift the whole floor or work from the underside.
fordv8j 07-27-2023 05:45 PM
we used 39 pedals on our 38 conv.-heated and bent to fit 38 floorboards, don't know if 38 and 39 are the same, mine had no floorboards, but I had a 38 pattern
TJ 07-27-2023 06:39 PM
I suspect if you use the 39 boards you need to use the 39 standard boards.
Kube 07-29-2023 09:47 AM
No difference to the '39 deluxe.
