Old 06-30-2023, 12:56 PM   #1
Lenny Bruce
Default Window Felt
Hi guys! My question today is do I have to remove my door windows to replace the felt? I was told to do so which isn’t a big deal but if it’s doable without taking them out that would be great!
Lenny Bruce is offline   Reply With Quote
Old 06-30-2023, 02:00 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Window Felt
You don't list what bodystyle, but the general answer is 'Yes'.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-30-2023, 02:02 PM   #3
JayJay
Lenny B - I assume you mean the felt channels that the windows ride up and down in. If so, whether you HAVE to remove the glass depends on what kind of car (as Brent pointed out). On the steel door cars the felts are held to the doors by clips, and you can (with difficulty) remove them by sliding them out after releasing the clips. On the wood frame doors (the fordors and Town Sedans) the felts are nailed to the wood frame, and you need to get the window out of the way to get to some of the nails.
If you are lucky and have a coupe or pickup, the top of the door unscrews and the window lifts out the top (after releasing the regulator). Either way, likely the easiest would be to just pull the windows out however you have to do it, that way if you have to put some muscle into the job you don't run the risk of damaging the glass.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 06-30-2023, 03:01 PM   #4
Lenny Bruce
That’s good to know thank you. Sorry it’s a ‘30 Tudor
Old 06-30-2023, 05:28 PM   #5
JayJay
I've not worked on a Tudor, so I don't know how the windows come out. Sorry.
JayJay
Old 06-30-2023, 10:13 PM   #6
Randy in ca
Randy in ca's Avatar
All Tudors also have the panel on the top of the doors - remove 3 screws - should be all that's holding it in place. Disconnect the regulator as mentioned in the previous post and everything should go out the top of door.
Randy in ca is offline   Reply With Quote
Old 07-01-2023, 06:14 PM   #7
Lenny Bruce
I will do just that! Thank you all!!!
