Old 07-20-2022, 04:09 AM   #1
rer_239
rer_239's Avatar
Default How to seal the gas tank
What's the best to seal. A gas tank?
Thanks
Dick
rer_239 is offline   Reply With Quote
Old 07-20-2022, 04:53 AM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: How to seal the gas tank
Have you done a search here ?
The subject is widely covered
https://www.fordbarn.com/forum/showt...=Gas+tank+seal
Old 07-20-2022, 07:04 AM   #3
Bob Bidonde
Bob Bidonde's Avatar
Do not put any non-metallic coating in your gas tank. These have a propensity to delaminate and clog the plumbing. If you have a leak, take the tank to a radiator shop for repair.
Bob Bidonde
Old 07-20-2022, 07:19 AM   #4
WHN
I sloshed the gas tank on our 1929 Sport Coupe about 35 years ago. You have to remove tank from car. Flush the tank as best you can. Than I sloshed the tank following manufactures instructions completely. Waited two days, and sloshed it again.
Buy a quality product from a well known supplier. You must follow the instructions. It’s not hard, and it works.
As I mention, 35 years, how much more can I say. No rust in gas line, no leaks around steering column support. I also installed a new Zenith carburetor. These two things did away with any fuel/carburetor issues car had.
“Must follow instructions”.
Good luck.
Old 07-20-2022, 12:47 PM   #5
ronn
I only use Hirsch. Have had great success with it and it holds up.(white in color and used in aircraft)
really better off using no sealer, if you can.
