Old 02-07-2022, 04:49 PM   #1
kurt v
Default 1940 throttle return spring broken
Can the return spring be replaced by pulling it up and off the shaft or do i have to take the shaft off of the firewall?
thanks kurt
kurt v is offline   Reply With Quote
Old 02-07-2022, 05:43 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: 1940 throttle return spring broken
Removing the assembly from the firewall makes it a little easier. I’ve done it both ways. Neither one is very easy.
Old 02-07-2022, 05:46 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
thanks kurt
I suspect you will have to find out for yourself if it is possible.
Old 02-07-2022, 07:30 PM   #4
Lawson Cox
Lawson Cox's Avatar
I second what Ken said.
Old 02-09-2022, 12:05 PM   #5
ssffnomad
ssffnomad's Avatar
Ok so last year I pull in a Bud’s place. Throttle goes wide open. Shut her down, vey the prob original return spring broke .
He comes out with a handful of throttle linkages with springs that he buys up at Swap Meets.
We had to pull shifter off trans, unhook and remove heater. Remove linkage and replace spring.
Hardest part is getting the bolts back in firewall with spring tension. You are going to want a tool similar to a “ Cotter Pin Extractor “ to pull up on bolt to align with firewall hole.
Bought a couple new repro springs , threw one in glove box.
Good Luck, Stretch
File Type: jpg EF212676-0E0E-419A-8474-514EDAA53122.jpg (29.3 KB, 13 views)
File Type: jpg CD106055-93A0-4594-AC46-A25B1CAD972D.jpg (31.0 KB, 12 views)
ssffnomad is offline   Reply With Quote
