Old 09-02-2021, 08:29 PM   #1
Ken/Alabama
Ken/Alabama's Avatar
Default 6 volt bulbs
Found some 6 volt LED bulbs that were a direct replacement.
File Type: jpg A4E055C4-D009-4F75-A999-7F45F87B0D37.jpg (33.0 KB, 359 views)
File Type: jpg 9A417BC3-1E1C-4755-8368-DCBCD5C61F8F.jpg (22.7 KB, 347 views)
Old 09-02-2021, 08:41 PM   #2
koates
Default Re: 6 volt bulbs
I also fitted some 6 volt LED bulbs to my original gauges in my 34 FORD. The original bulbs were very dull to my old eyes but the little LEDs fixed that. Make sure the LEDs are suitable to POS. or NEG ground to suit your car. Some are OK with both polarities. Regards, Kevin.
koates is offline   Reply With Quote
Old 09-02-2021, 08:42 PM   #3
petehoovie
petehoovie's Avatar
Source and part numbers?
Old 09-02-2021, 09:05 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Ken .....You gonna keep that info a secret? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 09-02-2021, 09:07 PM   #5
Ken/Alabama
Got them from Amazon. Search for 6 volt LED. On the taillight bulbs search for 6 volt 1157 LED. They have staggered pins unlike the original sockets. So I just replaced my taillight buckets with the reproductions that have staggered sockets.
Old 09-02-2021, 09:29 PM   #6
Ken/Alabama
Thought about it but I just can’t do my friends that way. 🤣
Old 09-02-2021, 09:48 PM   #7
19Fordy
19Fordy's Avatar
Thanks Ken for sharing your knowledge - shedding light on a dim subject.
Old 09-02-2021, 10:09 PM   #8
Lawson Cox
Lawson Cox's Avatar
Nice to know about the LED bulbs. I'll get some. To solve the staggered pins problem I've always just ground the offending pin. Worked for me.
Old 09-03-2021, 09:17 AM   #9
39portlander
39portlander's Avatar
Thanks for posting Ken, for those who might also have a Model T/A logolites have some very nice LED headlight either for +/- ground.
Check out logolights.com
39portlander is offline   Reply With Quote
Old 09-03-2021, 10:22 AM   #10
Anteek29
Anteek29's Avatar
Amazon also has 6 volt 1156 bulbs with the in-line pins.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 09-03-2021, 12:02 PM   #11
STEVE O
STEVE O's Avatar
Hi,
I assume these are not polarity sensitive?
Thanks
Steve
STEVE O is offline   Reply With Quote
Old 09-03-2021, 12:11 PM   #12
Ken/Alabama
Originally Posted by STEVE O View Post
Hi,
Thanks
Steve
Correct.
Old 09-03-2021, 12:22 PM   #13
STEVE O
STEVE O's Avatar
Thanks
Old 09-03-2021, 01:28 PM   #14
Fritz
Fritz's Avatar
LEDs make a big difference. I bought different ones from superbrightled.com a few years ago, however I believe the cheap China made product overheated and caused the bulb to burst and fail. Just something to keep an eye on to make sure they hold up.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
Old 09-03-2021, 02:44 PM   #15
JT FORD
JT FORD's Avatar
Ken did you use red or white like the originals. These bulbs should be much cooler than the originals. Did you notice the difference?
JT FORD is offline   Reply With Quote
Old 09-03-2021, 04:47 PM   #16
Lawson Cox
Lawson Cox's Avatar
Kevin. Got any numbers for the dash lights? I need em bad om ny 35PU. Can't see it.
Old 09-03-2021, 07:05 PM   #17
Ken/Alabama
White.
Old 09-03-2021, 10:50 PM   #18
V8COOPMAN
V8COOPMAN's Avatar
Ken .....I really do appreciate you coming back with the info and pics, especially for your friends! DD
T5 W/TORQUE TUBE
Old 09-04-2021, 08:40 AM   #19
Eric T
Thanks for the information.
While lighting is waaaaaaaaaay down the road on my 1950 Fordor, I was hoping I could find LED replacements .
Eric T is offline   Reply With Quote
Old 09-04-2021, 11:26 AM   #20
Anteek29
Anteek29's Avatar
OOPS...The 1156 bulbs are 12 volt - not 6 volt
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
