Old 07-17-2021, 11:19 AM   #1
rfequity
Default GAV housing threads
What is recommended to seal around the GAV housing threads to stop fuel leak?
rfequity is offline   Reply With Quote
Old 07-17-2021, 12:24 PM   #2
Ed in Maine
Default Re: GAV housing threads
I would use non-hardening Permatex gasket sealer. You have to be able to remove the GAV in the future. The gasoline is only about 3/8 in. above the top of the casting with the level set at 5/8 in. This is a very low pressure for the gas to leak by the threads. Ed
Old 07-17-2021, 08:42 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I've never had one leak there, but if I did, I'd do the same as Ed just said.
