The Ford Barn
-   -   GAV housing threads (https://www.fordbarn.com/forum/showthread.php?t=301287)
rfequity 07-17-2021 11:19 AM
GAV housing threads
What is recommended to seal around the GAV housing threads to stop fuel leak?
Ed in Maine 07-17-2021 12:24 PM
Re: GAV housing threads
I would use non-hardening Permatex gasket sealer. You have to be able to remove the GAV in the future. The gasoline is only about 3/8 in. above the top of the casting with the level set at 5/8 in. This is a very low pressure for the gas to leak by the threads. Ed
Tom Wesenberg 07-17-2021 08:42 PM
I've never had one leak there, but if I did, I'd do the same as Ed just said.
