Old 07-14-2021, 08:08 PM   #1
russcc
Default Weatherhead fitting source.
I have used an early, (1970's), Weatherhead adapter fitting that works great
when you have a none stock fuel system in an early V8 Ford. Up until recently I was able to get them from the local NAPA store, but they ran out of old inventory, The fitting adapts the Ford 1/4" male compression type fitting to 1/8" pipe thread which provides more hookup options. Anyone know a source for these. The original Weatherhead # is 1513. See photos. Thank you.
Old 07-14-2021, 10:11 PM   #2
leon bee
Default Re: Weatherhead fitting source.
Here's about the only thing I saw:
https://www.hydraulicstore.com/conne...atherhead.html
leon bee is offline   Reply With Quote
Old 07-14-2021, 10:13 PM   #3
leon bee
Here's another. Those things must be gold plated:
https://www.applied.com/c-brands/c-e...er/p/105267304
Old 07-14-2021, 10:18 PM   #4
Bob C
Try Renner's Corner. I think item B-92288-FLA is what your looking for.
Fourth item down at the link. https://www.rennerscorner.com/carburetor.html
Old 07-15-2021, 05:00 AM   #5
russcc
Thank you all for the tips. emailed David at Renner's Corner. This is the application I use this fitting in,
Old 07-15-2021, 08:32 AM   #6
uncle buck
uncle buck's Avatar
Take a look at a Gates # G49240-0204 fitting. It should be the same thing and is readily available from your NAPA store
File Type: jpg EB9D530B-59C8-429A-BA13-D2429D96A502.jpg (55.0 KB, 32 views)
uncle buck is offline   Reply With Quote
Old 07-16-2021, 05:37 AM   #7
russcc
Thank you. Will check that out.
