The Ford Barn
-   -   Weatherhead fitting source. (https://www.fordbarn.com/forum/showthread.php?t=301189)
russcc 07-14-2021 08:08 PM
2 Attachment(s)
I have used an early, (1970's), Weatherhead adapter fitting that works great
when you have a none stock fuel system in an early V8 Ford. Up until recently I was able to get them from the local NAPA store, but they ran out of old inventory, The fitting adapts the Ford 1/4" male compression type fitting to 1/8" pipe thread which provides more hookup options. Anyone know a source for these. The original Weatherhead # is 1513. See photos. Thank you.
leon bee 07-14-2021 10:11 PM
Re: Weatherhead fitting source.
Here's about the only thing I saw:
https://www.hydraulicstore.com/conne...atherhead.html
leon bee 07-14-2021 10:13 PM
Here's another. Those things must be gold plated:
https://www.applied.com/c-brands/c-e...er/p/105267304
Bob C 07-14-2021 10:18 PM
Try Renner's Corner. I think item B-92288-FLA is what your looking for.
Fourth item down at the link. https://www.rennerscorner.com/carburetor.html
russcc 07-15-2021 05:00 AM
1 Attachment(s)
Thank you all for the tips. emailed David at Renner's Corner. This is the application I use this fitting in,
uncle buck 07-15-2021 08:32 AM
1 Attachment(s)
Take a look at a Gates # G49240-0204 fitting. It should be the same thing and is readily available from your NAPA store
russcc 07-16-2021 05:37 AM
Thank you. Will check that out.
