Old 05-04-2021, 11:31 AM   #1
jayvee34
jayvee34's Avatar
Default U-joint special washer
Does anyone know what the special washer in the U-Joint bolt up to the output shaft on the transmission purpose is? When I changed my transmission there
was not one, only a lock washer. Does it prevent a problem by not having one?
Thanks for any input or answer.
John
jayvee34 is offline   Reply With Quote
Old 05-04-2021, 11:45 AM   #2
Tim Ayers
Default Re: U-joint special washer
Yes, you need it. It's actually a type of spring that has a specific type of name that I'd assume was name after the inventor. When you look, it's slightly concaved and this allows for some slight movement while still being substantial enough to hold the input shaft while also taking the force of the drive shaft wanting to push the U-joint forward and aft.
Old 05-04-2021, 11:45 AM   #3
Y-Blockhead
Y-Blockhead's Avatar
John
Hold the u-joint on the transmission output shaft. https://www.brattons.com/universal-j...-and-bolt.html I can't imagine Ford would of put it on there if they didn't think it was necessary.
Old 05-04-2021, 12:02 PM   #4
Tom Endy
Tom Endy's Avatar
The flat washer with the notch in it fits over the end of the transmission output shaft and prevents oil from leaking out through the splines. The Mitchell company offers one that has a rubber seal associated with it. They provide one with each of their synchro transmissions.
Tom Endy
Old 05-04-2021, 12:04 PM   #5
john charlton
john charlton's Avatar
The edge of the dished washer has an upset to engage a spline end .This stops the washer turning when you tighten it up .
John in cool wet windy Suffolk County England .
Old 05-04-2021, 12:10 PM   #6
redmodelt
redmodelt's Avatar
We are talking about the keyed washer that holds the u-joint to the output shaft? It is there to prevent the u-joint from moving back and forth to maintain the proper center line of same. For the Model T the u-joint was pinned to the drive shaft both for thrust control and keep that center. The Model A being setup different re thrust but still needed to keep it centered, attached to to the output shaft.
Old 05-04-2021, 12:20 PM   #7
jayvee34
jayvee34's Avatar
Thanks for all the input, looks like it is essential, and I will be getting one.
Thanks again, John
