Old 09-10-2020, 11:05 AM   #1
RocketsGarage
RocketsGarage's Avatar
Default Help with "Full Race" cam ID
385 S-T Looking for info on this cam. I believe it's an Almquist 385 S-T but cannot find much info. Anyone know? It's not in my possession I'm considering buying it.
www.RocketsGarage.com
RocketsGarage is offline   Reply With Quote
Old 09-10-2020, 11:29 AM   #2
Tim Ayers
Default Re: Help with "Full Race" cam ID
https://www.jalopyjournal.com/forum/...st-385.370197/
Old 09-10-2020, 11:36 AM   #3
RocketsGarage
I found that thread but I didn't see where it actually list the cam. That's what made me think it was an Almquist grind though.
Old 09-12-2020, 11:08 AM   #4
RocketsGarage
I bought the cam so I'll be able to hopefully measure it out but would still like to see some old info. My 1950 Almquist catalog doesn't list it.
Old 09-12-2020, 01:31 PM   #5
JSeery
JSeery's Avatar
Might contact Pete here on the Barn.
Old 09-12-2020, 04:03 PM   #6
Ronnieroadster
Ronnieroadster's Avatar
The number 385 I would expect that is the lift dimension. Not really a full race cam if its only 385 lift. To be sure of the lift dimension measure the heal diameter and then the height of the lobe. Next subtract the heal measurement from the lobe height thats the lift of the cam.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 09-12-2020, 06:17 PM   #7
KiWinUS
KiWinUS's Avatar
I have an Almquist 600 it has .350 lift.
Old 09-15-2020, 10:30 AM   #8
RocketsGarage
Ronnieroadster
Thanks. I'll try that when I get it.
Old 09-15-2020, 02:09 PM   #9
Ol' Ron
Ol' Ron's Avatar
Not many early "Full Race" cams had very high lift. Isky was probably ine of the first that came close to the .400 lift range. The base circle determine the max lift. Using new cam cores raised the price of the cam, and the name "full Racr" was more of an advertising Ploy to sell more cams. I have a "cleveland Hone came with 28-72 int .350
62-22 ex lift .335 and this cam was ground in 1937. This cam was/ stil is running in a 27 T roadster in a 239 stock engine. The car isn\t that fast, but the sound comes from Heaven
Old 09-21-2020, 04:21 PM   #10
RocketsGarage
I was able to measure the lift & it roughly measures .321" Seems small?
Old 09-21-2020, 05:14 PM   #11
Tim Ayers
Kind of, but maybe not be totally true. Duration is the next measurement you need to figure out. I had a Weber cam at one time that had something like .350" lift with almost 290 degrees of duration. The lobes were literally like table tops.
Old 09-23-2020, 11:41 AM   #12
RocketsGarage
That looks like the case. Here it is compared to a Potvin 425" lift cam I have.
Old 09-23-2020, 07:22 PM   #13
Bored&Stroked
Bored&Stroked's Avatar
The lift is small . . . definitely not what I'd call "Full Race". BUT - as others have noted, the terms of "3/4" and "Full Race" were marketing terms - really just something to help uneducated hotrodders have some bragging rights. Many a guy could tell you he had a "full race" cam - without any clue as to what his specific specs actually were. LOL
Who ground your Potvin 425? From the picture, the lobes don't look quite correct (the profile at the peak) - but I might be seeing things. There are a lot of copies in the world, many of which are not really done as they should be.
Good luck with all your cams . . . don't yah just love how your mind gets into these darn bump sticks! LOL
Old 09-23-2020, 07:30 PM   #14
Pete
Lotsa wear on that 425.
Old 09-24-2020, 10:43 AM   #15
RocketsGarage
It was ground by Schneider
Old 09-24-2020, 11:02 AM   #16
Tim Ayers
I would get that 425 cleaned up before you decide to use it. It looks pretty grungy and rusty.
Old 09-24-2020, 12:24 PM   #17
RocketsGarage
The gross looking one is the ST 385 cam. It's covered in cosmoline. It'll need some cleanup though
Old 09-24-2020, 12:31 PM   #18
Tim Ayers
Ah, got it.
