Old 08-14-2020, 03:14 PM   #1
bgalla
Default brake squeak
My recently restored 36 has a single wheel squeak when the brake is applied, but only the last 10-20 feet before a completed stop. I have driven 100 miles on the new shoes and no change. Any ideas? Thanks Bruce
bgalla is offline   Reply With Quote
Old 08-14-2020, 04:40 PM   #2
alanwoodieman
Default Re: brake squeak
sounds like a little oil/grease is on the lining. try spraying brake cleaner on the shoes--hard to do but try
Old 08-15-2020, 07:41 PM   #3
1931 flamingo
1931 flamingo's Avatar
I'd keep driving it. Are the shoes chamferred on the leading/trailing edges??
Paul in CT
Old 08-15-2020, 09:03 PM   #4
fordor41
fordor41's Avatar
ditto on chamferring the egdes
fordor41 is offline   Reply With Quote
Old 08-16-2020, 07:21 AM   #5
Frank Miller
Frank Miller's Avatar
Squeaks are usually from the metal to metal parts. My dad has a squeak in his Model a and I lubricated all the rollers pins and what not and that pretty much cleared it up. Used permatex brake grease.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 08-16-2020, 10:36 PM   #6
fordor41
fordor41's Avatar
not necessarily, shoes & disc pads with sharp 90 deg, edges can squeal.
Old 08-16-2020, 11:38 PM   #7
50fordcoupeman
50fordcoupeman's Avatar
While chamferring, lightly run some 600 grit over the shoes and brake drum to remove any junk that may be on there.
50fordcoupeman is offline   Reply With Quote
Old 08-17-2020, 03:54 PM   #8
FlatheadTed
FlatheadTed's Avatar
Can be ,The new type soft lining when it gets glassed make a noise its the copper type wire imbed in the material ,try all the above fixes and 50 coup mans ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
