Hi Fordbarn,
I just got a set of Reds Headers for my 39 Sedan and it came with a bolt kit but no washers. What are your thoughts? Should I pick up a set of lock washers? Locktite? Just use the bolts as is? Thanks for your input. Chris |
I use flat washers and antiseize compound. I am afraid the lockwashers will
crack and break due to expansion and contraction and loose their effectiveness. No Loctite. |
I did the same. Use a good grade washer and hi temp anti-seize. Check torque every 6 months or so.
