The Ford Barn
-   -   Reds Headers. Washers? (https://www.fordbarn.com/forum/showthread.php?t=282702)
Chris_AAFord 06-16-2020 06:46 PM
Hi Fordbarn,
I just got a set of Reds Headers for my 39 Sedan and it came with a bolt kit but no washers.
What are your thoughts? Should I pick up a set of lock washers? Locktite? Just use the bolts as is?
Thanks for your input.
Chris
19Fordy 06-16-2020 10:42 PM
Re: Reds Headers. Washers?
I use flat washers and antiseize compound. I am afraid the lockwashers will
crack and break due to expansion and contraction and loose their effectiveness.
No Loctite.
Zax40 06-17-2020 09:35 AM
No Loctite.
I did the same. Use a good grade washer and hi temp anti-seize. Check torque every 6 months or so.
vilanar 06-17-2020 03:09 PM
Nord-Lock washers and anti seize. With those washers they will stay tight.
