Old 04-25-2017, 07:06 PM   #1
Tinbasher
Tinbasher's Avatar
Question How was the top bolt for the rear mounted spare
Hi guys: I'm working on my 28 Sport Coupe with a rumble seat. How was the top bolt put into the spare wheel brkt. Was there a hole through the inner rumble seat panel? It looks impossible to put the bolt in from underneath.
Pictures would be good.
Thanks: John Poole
Tinbasher is offline   Reply With Quote
Old 04-25-2017, 08:02 PM   #2
wrndln
Default Re: How was the top bolt for the rear mounted spare
For a rumble seat car, the curved inner panel has a steel reinforcing part riveted to the sheetmetal panel to support the spare tire. The bolt for the spare tire bracket that goes into the large D nut on the top of the spare tire bracket and is installed from the top (inside). There is a hole for the bolt that passes through the steel bracket and sheetmetal inner panel, through the hole in the panel below the deck lid and into the large D nut. The attached picture show the inner panel and steel bracket, but I couldn't find a picture of the top side showing the bolt head.
Rusty Nelson
File Type: jpg Model A Roadster - Rear Curved Inner Panel & Brace 003.jpg (61.9 KB, 156 views)
Old 03-19-2020, 09:14 AM   #3
dmaxweb
dmaxweb's Avatar
Rusty Nelson
I discovered my 30 rumble seat coupe with rear spare does not have the banana brace. The curved inner panel does not have the access hole which is probably why they didn't put one on. Is the hole just a rectangular cut out? Rather than taking panels apart, I'm thinking about using hole saw to cut a round hole just big enough for a socket to tighten the bolt. Thoughts?
dmaxweb is offline   Reply With Quote
Old 04-26-2017, 09:57 PM   #4
Tinbasher
Tinbasher's Avatar
Thanks Rusty: That makes more sense. Another repro part that's half right. I'll have to look for an original inner panel for the rumble seat.
John Poole
Old 04-27-2017, 12:47 AM   #5
Doug Clayton
The rear inner panel is different on the early 1928 rumble seat models. They did not have the brace like Rusty shows in his photos (and no square hole in the inner panel). The bolt only went through the outer curved panel and "T" shaped brace into the tire carrier. If you have Revision 4 to the Guidelines there are pictures of both types.
Doug Clayton is offline   Reply With Quote
Old 04-27-2017, 09:53 PM   #6
Tinbasher
Tinbasher's Avatar
Thanks Doug: I'll check that out as well.
John
