I've seen videos of people changing Model A tires with the wheel still on the car. Has anybody here ever changed the rear tire of their lawn tractor with the wheel still on the axle? Can't get my wheel off.
In days long gone by, the shop where I bought my tires habitually changed the tires WITHOUT removing the wheel from the vehicle. This was in the 1950's, and the tire size was 6:00-16. With tubes.
And, by the way, they had a static balancer they used to 'balance' the tire, before putting in on the wheel. |
Yes I have. Turn it on its side and have at it.
It works well.Remove with the stem at the top,and mount with the stem at the bottom.Lock the hub up with the brake adjuster,if you don't you will chase the bead around in circles with the tire iron.
I just changed tubes in two tires while on the car. It is easier, atleast for me to do it off the car but it can be done while on it.
#6 | |
BTW, what size is the tire? The smaller they are, the tougher they are to change. |
#7 | |
![]() Quote:
18 X 8.5 8 Not as small as the fronts, but pretty small. I'm going to give getting the wheel off one more try. Reminds me too much of getting the rear hubs off my Model A! Wish I could use that puller on these, Thanks for the help and advice everyone. |
I would have another go at getting the wheel off. I did one on mine earlier this year. Would have been an absolute pain to do on the axle. Much easier to seat the bead with ether with the wheel off too
