Old 03-03-2019, 07:49 AM   #1
Henry Hopper
Henry Hopper's Avatar
Default T5 Speedo question
I’m in the process of getting the parts ready to fit a T5 into the Cabriolet and would like to know how others have sorted out the speedometer problem.The trans I am intending to use has the electronic speedo version.I would like if at all possible to keep my original speedo and don’t want a gps one either.
I’m guessing an electronic aftermarket speedometer is going to be the answer but thought I’d throw it out there to see what others have come up with.
Henry Hopper is offline   Reply With Quote
Old 03-03-2019, 09:10 AM   #2
rick r
rick r's Avatar
Default Re: T5 Speedo question
Speedhut makes a unit that allows you to connect a mechanical spedo to a trans that has an electronic drive. Google Speedhut.com
rick r is offline   Reply With Quote
Old 03-03-2019, 09:18 AM   #3
40cpe
40cpe's Avatar
Here is the link
https://www.speedhut.com/ecommerce/p...peed-Converter
Old 03-03-2019, 10:16 AM   #4
Henry Hopper
That’s a nifty little thing
Old 03-03-2019, 11:35 AM   #5
TomT/Williamsburg
TomT/Williamsburg's Avatar
There is an advertiser on the Hamb that converts your electronic tail shaft to a mechanical. Or, just find a mechanical tail shaft T5 and swap it out. In either case in my old 40 coupe with T5 I was able to use the stock 40 speedo cable and if memory serves me it was about 5mph off .... but that all depends on rear gear, tire size. Now, to be truthful, I use a cheap eBay purchased used Tom Tom and my speed is calculated by it.
TomT/Williamsburg is offline   Reply With Quote
Old 03-03-2019, 12:01 PM   #6
old school rodder
I've used the conversion referenced above. Search for Kato Kings on the HAMB. he can convert your electronic to mechanical and if you tell him gear ratios and tire size, it'll be set up accurately. He knows his stuff.
old school rodder is offline   Reply With Quote
Old 03-03-2019, 01:58 PM   #7
my4dv8
Abbott industries make a speedometer adapter electronic in to cable out .http://www.abbott-tach.com/cablex.htm
I think these are USA made . Great unit , but a PIA to calibrate but once you are done calibrating to get the exact speed you are done.
Or this way , a hidden Sky drive unit with a cable drive out put .
https://www.classicautoinnovations.com/
my4dv8 is offline   Reply With Quote
Old 03-03-2019, 02:39 PM   #8
jrvariel48
jrvariel48's Avatar
I've had a cable X box for about 4 years. Works perfectly!
jrvariel48 is offline   Reply With Quote
