Old 05-22-2016, 07:20 AM   #1
Utopia Texas
Utopia Texas's Avatar
Default Need Confirmation On Head Gasket Placement...
Copper type head gasket. Does the raised crimped edge side go towards the block and flat side go towards the head? thanks...
Utopia Texas is offline   Reply With Quote
Old 05-22-2016, 07:33 AM   #2
Royce P
Royce P's Avatar
Default Re: Need Confirmation On Head Gasket Placement...
The larger water hole goes to the rear. The smaller water hole goes at the front. The crimp location is not important.
1910 Touring
1914 Touring
1915 Touring
1917 Torpedo Runabout
Royce P is offline   Reply With Quote
Old 05-22-2016, 07:44 AM   #3
James Rogers
James Rogers's Avatar
The crimp goes to the head. There is always a slight amount of movement between the head and block which will etch the gasket into the cast. It is easier to re-surface the head than the block to get rid of this.
James Rogers is offline   Reply With Quote
Old 05-22-2016, 09:20 AM   #4
redmodelt
redmodelt's Avatar
Crimp side up. As James said above.
Old 05-22-2016, 09:47 AM   #5
Mitch//pa
Go with posts 3 & 4....
Old 05-22-2016, 11:59 AM   #6
WestCoast
if you get a head gasket grove worn in the block you will wish you had listened to the other guys, not an easy task to get a block to the machinest to have the block surface trued
WestCoast is offline   Reply With Quote
Old 05-22-2016, 04:55 PM   #7
C26Pinelake
Mr. Rogers is an expert, follow his advice and you can never go wrong! Wayne
C26Pinelake is offline   Reply With Quote
