Need Confirmation On Head Gasket Placement... Copper type head gasket. Does the raised crimped edge side go towards the block and flat side go towards the head? thanks...
Re: Need Confirmation On Head Gasket Placement... The larger water hole goes to the rear. The smaller water hole goes at the front. The crimp location is not important.
Re: Need Confirmation On Head Gasket Placement... The crimp goes to the head. There is always a slight amount of movement between the head and block which will etch the gasket into the cast. It is easier to re-surface the head than the block to get rid of this.
Re: Need Confirmation On Head Gasket Placement... Crimp side up. As James said above.
Re: Need Confirmation On Head Gasket Placement... Go with posts 3 & 4....
Re: Need Confirmation On Head Gasket Placement... if you get a head gasket grove worn in the block you will wish you had listened to the other guys, not an easy task to get a block to the machinest to have the block surface trued
Re: Need Confirmation On Head Gasket Placement... Quote:
