How do you prime a model B oil pump?
Pour a quart of oil down the distributor hole in the head.
Thanks....For your help, but in second thought would be already be primed because on the model B as on the model A the pump intake screen already sits in the oil in the plan?
I always prime / fill the pump with assembly lube if I can’t prime with a drill.
While it is good idea to prime a V8 pump except perhaps the first design used on the earliest '32s, the very nature of a Model A or B oil pump (and the first '32 V8 pump version) is that they are self priming by virtue of their open bottom being immersed in four plus inches of oil.
#6 | |
so that almost anyone can operate. |
Can the distributor be removed and the oil pump be spun like in some other V8's?
Don't never get rid of nuthin! |
No the oil pump is driven from the back of the cam, maybe pour some oil down the breather tube might get some oil in that way. Like other's have said it is covered in oil in the pan and should not need priming. Al
With respect, this is a four-cylinder pump he is asking about which is driven off the center of the camshaft, not off the rear. The breather tube/oil filler tube is on the other side of the engine and not aligned with the pump.
