Old 08-28-2018, 07:59 PM   #1
walkerlakeprinter
walkerlakeprinter's Avatar
Default Adjusting wedge lubrication?
When installing a new brake adjusting wedge in my front backing plate, should I pack the inside with grease before putting on a new dust cap? I've seen places that don't mention it, but say to use brake lubricant.
walkerlakeprinter is offline   Reply With Quote
Old 08-28-2018, 11:48 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Adjusting wedge lubrication?
I use high temp grease on all moving parts, and the wedge is a moving part.
Old 08-29-2018, 06:56 AM   #3
marty in Ohio
marty in Ohio's Avatar
A friend did a complete brake job and couldn't get one of the drums back on afterwards. He thought a drum had shrunk in the process. (Pretty hard to do.) A few of us suggested that the adjusting wedge was out too far. He took it all apart, cleaned the dirt out of the wedge, lubed it, and all went back together like new.
Marty
marty in Ohio is offline   Reply With Quote
Old 08-29-2018, 01:05 PM   #4
SeaSlugs
SeaSlugs's Avatar
I put anti sieze on the threaded portion and a smear of high temp grease on the wedge itself.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
