Old 07-09-2018, 08:44 AM   #1
Daddio
Daddio's Avatar
Default Inside OEM Style Repop Battery
My OEM style repop battery finally gave up the ghost and, since there was a long lead time on a replacement, I had to get a lead acid instead. Man, is it ugly ... I'm saving my allowance for a 'proper' replacement.
I decided to carefully cut the repop apart just to see what's inside, but still be able to use it as a display. I thought you might like to have a look.
An teeny weeny AGM battery, set sideways, stuck to the bottom of the case with about an inch of epoxy and wired to the external top terminals.
This AGM is about the size of the battery in my lawn tractor!! After seeing this, I'm surprised it was able to spin over 390 cubes for the past 10 years!!
Daddio is offline   Reply With Quote
Old 07-09-2018, 10:01 AM   #2
KULTULZ
KULTULZ's Avatar
Question Re: Inside OEM Style Repop Battery
Where did you source it - name of manufacturer/vendor?
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 07-09-2018, 11:03 AM   #3
Oldmics
Default Re: Inside OEM Style Repop Battery
How did you manage to do such a nice clean and even cut ?
I knew there was an AGM inside as you can see it thru the top of the battery caps.
I too am in the process of slicing one apart but its a dirty messy job.
Oldmics
Oldmics is offline   Reply With Quote
Old 07-09-2018, 11:22 AM   #4
Daddio
Daddio's Avatar
I bought this one and another for my TBird at Carlisle 10 or so years ago. The one in the Bird is still goin' strong! The supplier is now out of business, but this guy https://batterycentralmall.com/Batte...ript/S60K.html has taken over (with a $200 increase in price it appears).
I cut the top off about 1" down at the 'seam' with a thin blade hack saw. I couldn't get the AGM out because of the 1" of epoxy holding it, so I drilled 4 holes thru the bottom and used a jig saw with medium toothed blade to cut around the battery. It dropped right out. I got some black silicone and glued the top back on the case.
If I was to do it again, I'd just drill the 4 holes and jig saw it out, leaving the top and sides of the case intact. Keep close to the edge along the long sides, the AGM is pretty tight in there. You should be able to snip the wires to the top terminals.
Old 07-09-2018, 03:06 PM   #5
Automotive Stud
Automotive Stud's Avatar
I wonder now if you can get a replacement AGM battery like that and stuff it back in your case?
Automotive Stud is offline   Reply With Quote
Old 07-10-2018, 10:55 PM   #6
fordor41
fordor41's Avatar
My portable "jumper" box went south and I took it apart and found a small battery also. Would hold a charge all winter and start any car. Found a replacement at an Exide dealer.
fordor41 is offline   Reply With Quote
Old 07-11-2018, 08:03 PM   #7
miker98038
miker98038's Avatar
It’s nothing but a guess looking at the picture, but it looks a lot like the Odessey AGM I use. 10 years and starting a big block is no big deal if they’re disconnected over the winter. Not cheap except in the long run.
miker98038 is offline   Reply With Quote
Old 07-11-2018, 09:36 PM   #8
34pickup
34pickup's Avatar
I have had one of those Odyssey batteries that size also for a number of years. It has been starting a 302 Ford with no problem. I think it has about 600 cca's in that small package. I keep it on a battery tender when not in use.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 07-11-2018, 09:46 PM   #9
Herman Munster
Herman Munster's Avatar
And I thought they were actually lead acid batteries. Makes sense. I doubt you can ship an actual lead acid battery unless it was dry. Then how would you bring it to life?
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic
Herman Munster is offline   Reply With Quote
Old 07-11-2018, 10:10 PM   #10
miker98038
miker98038's Avatar
We used to do that in remote areas with the boats. The local guy kept the acid in stock, and in a shorter time they flew or water shipped the battery in. He filled it, charged it, and we took it from there. Wasn’t cheap, but apparently a barrel of acid wasn’t much more than a quart to transport. Not much choice on the inside passage to Alaska if something failed.
