Old 05-02-2018, 09:19 PM   #1
Gick70
Default 52 ford f1 fill up
When stopping for fuel ,adding fuel,I stop later down the road and the filler neck always drools fuel and I didn't even fill it to the top! Any solution for this?
Gick70 is offline   Reply With Quote
Old 05-02-2018, 09:51 PM   #2
FirstGenF2
FirstGenF2's Avatar
Default Re: 52 ford f1 fill up
Did you drive down a rough or angled road, is the tank baffled, is the gas cap vented, and what temperature is it in the cab, has there been a major temp shift?
51' F2
45' CJ2a
FirstGenF2 is offline   Reply With Quote
Old 05-03-2018, 02:28 AM   #3
FortyNiner
FortyNiner's Avatar
Where is the leakage? End of tube? At the rubber sleeve?
Old 05-03-2018, 12:59 PM   #4
cmbrucew
cmbrucew's Avatar
Fuel pumped from a tank 20 feet below ground is cool.
When you add it to your tank it warms up and expands. I have learned not to fill it to the top, unless I am going cross country. It is parked on the street which is crowned so gas runs out when it parked. My solution is when guage indicates 1/4 full I add 10 gallons plus 4 OZ. MMO.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 05-04-2018, 03:22 PM   #5
Gick70
The leak is down my truck ,it's not coming from the cap,maybe I got to torque on the clamps holding the rubber sleeve!!
Old 05-04-2018, 03:24 PM   #6
Gick70
I,m also working on getting my gauges to work,so then I won,t feel the need to top it off all the time!
Old 05-04-2018, 03:47 PM   #7
Ross F-1
Ross F-1's Avatar
I let the station's pump kick off the nozzle, which usually occurs when the gas is up to the bottom of the fill tube. No problems with sloshing. I replaced the rubber sleeve where the tank and filler tube join, and bought a modern vented locking gas cap: Stant 10491
https://www.amazon.com/Stant-10491-L.../dp/B000C7YQ2E
(fits '51 - '52)
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
