Old 10-17-2017, 01:59 PM   #1
Brian T
Brian T's Avatar
Default USA made U-Joint.
I am seeking information from any long time model A ford folks that may know of this brand of U-joint, and the quality thereof , it is clearly marked USA made, inside the box that is well worn, there is an application chart, the last listing is 1961, it is surplus to my needs, so I may consider selling it.
Any info much appreciated.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 10-17-2017, 02:22 PM   #2
Brian T
Brian T's Avatar
Default Re: USA made U-Joint.
Added more pictures.
Old 10-17-2017, 07:32 PM   #3
Russ/40
Russ/40's Avatar
Since the packaging is period, and it is USA made, I'd feel perfectly fine with it.
Old 10-17-2017, 07:39 PM   #4
glenn in camino
glenn in camino's Avatar
I think I have a used one like that. Will be for sale at the 2018 MAFCA national swap meet. June 24th 2018.
Old 10-17-2017, 10:00 PM   #5
ursus
That brand of U-joint is a well made product and much better than anything made these days.
Old 10-17-2017, 10:23 PM   #6
Pete
Old 10-18-2017, 12:44 AM   #7
Brian T
Brian T's Avatar
Hi Pete,
You asked if the U-joint has bushings or needle bearings, it has bushings.
Old 10-17-2017, 10:53 PM   #8
100IH
So, you say that there is an application chart, Have to wonder if it applies to model A.
100IH is offline   Reply With Quote
Old 10-18-2017, 12:34 AM   #9
Brian T
Brian T's Avatar
Yes, it is in the application chart, 11090, and is also on one panel of the box so it is for a model A.
Old 10-18-2017, 12:49 AM   #10
KR500
KR500's Avatar
Pilot was a well known manufacturer. They made king pins, hydraulic brake parts, and some front end parts. They are comparable to Thompson, McQuay Norris, Toledo, and Nylint.
KR500 is offline   Reply With Quote
Old 10-18-2017, 11:20 PM   #11
Drive Shaft Dave
I wouldn't be afraid to use it. Was it made in Milwaukee?
Drive Shaft Dave is offline   Reply With Quote
Old 10-19-2017, 01:51 PM   #12
hardtimes
hardtimes's Avatar
Hey Brian,
I have one (twin to yours ).
Luckily , a guy does not often have to swap/change out a U-joint. But, I have held onto this one forever...because made in USA and none better will ever come along, IMO. So, will continue it in storage, comforted knowing that it will be there if/when needed !
