Old 03-02-2021, 01:06 PM   #1
samsonized
Default front wishbone and axle
i have a couple of front wishbones and front axles that i am trying to identify. i think they are off a 36 but not sure i have a 34 cabriolet that i have been told has a later front end in it. how do i identify what year the front wishbone is and what year the front axle is
samsonized is offline   Reply With Quote
Old 03-02-2021, 01:21 PM   #2
TJ
TJ's Avatar
Default Re: front wishbone and axle
A photo would be very helpful.
Old 03-02-2021, 01:23 PM   #3
samsonized
i was more or less looking for dimensions but i can try and get some pix
Old 03-02-2021, 01:31 PM   #4
Will D
Will D's Avatar
Does this help?
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
Old 03-02-2021, 01:34 PM   #5
Mart
Mart's Avatar
34 has spring above.
35 on has spring in front.
35/36 wishbones flare out in front of the axle.
37-40 are straight in front of the axle.
There's a start for you.
It's a lot harder for us to tell you what you have without seeing it, than it is for you to take a pic. Work with us and we will do our best to help.
Old 03-02-2021, 01:35 PM   #6
samsonized
are the spring perch holes in the axles all in the same place is there a measurement that would tell which is which
Old 03-02-2021, 01:37 PM   #7
Will D
Will D's Avatar
Dimensions on here:
https://m.roadkillcustoms.com/early-...nd-dimensions/
Old 03-02-2021, 01:38 PM   #8
Mart
Mart's Avatar
32-36 are the same, 37 up are wider.
It took me 10 seconds to do a google search.
Old 03-02-2021, 02:50 PM   #9
samsonized
thanks for your help mart
