The Ford Barn
-   -   front wishbone and axle (https://www.fordbarn.com/forum/showthread.php?t=295200)
samsonized 03-02-2021 01:06 PM
i have a couple of front wishbones and front axles that i am trying to identify. i think they are off a 36 but not sure i have a 34 cabriolet that i have been told has a later front end in it. how do i identify what year the front wishbone is and what year the front axle is
TJ 03-02-2021 01:21 PM
Re: front wishbone and axle
A photo would be very helpful.
samsonized 03-02-2021 01:23 PM
i was more or less looking for dimensions but i can try and get some pix
Will D 03-02-2021 01:31 PM
1 Attachment(s)
Does this help?
https://www.fordbarn.com/forum/attac...1&d=1614709889
Mart 03-02-2021 01:34 PM
34 has spring above.
35 on has spring in front.
35/36 wishbones flare out in front of the axle.
37-40 are straight in front of the axle.
There's a start for you.
It's a lot harder for us to tell you what you have without seeing it, than it is for you to take a pic. Work with us and we will do our best to help.
samsonized 03-02-2021 01:35 PM
are the spring perch holes in the axles all in the same place is there a measurement that would tell which is which
Will D 03-02-2021 01:37 PM
Dimensions on here:
https://m.roadkillcustoms.com/early-...nd-dimensions/
Mart 03-02-2021 01:38 PM
32-36 are the same, 37 up are wider.
It took me 10 seconds to do a google search.
https://www.jalopyjournal.com/forum/...t-jpg.4204580/
samsonized 03-02-2021 02:50 PM
thanks for your help mart
